Old 05-11-2018, 08:51 AM   #21
Originally Posted by Beards79 View Post
Had a similar problem with our 2012, the front turn signals wouldnít work with the headlights on.. the problem was inside that same group of wires. The guy who installed the connectors went overkill with the heat gun while melting the shrink tube and melted all the connectors together causing a short I replaced all them and the problem was fixed. That group of wires has been the source of many peopleís lighting problems!
I did see some melting of the wires and some of the wire labels where melted to nothing.
2021 Dynamax Force HD
2017 Forest River Georgetown 364TS
TexasChris is offline   Reply With Quote
Old 05-11-2018, 09:02 AM   #22
Beards79's Avatar
Yep, quality control is def not a huge concern in the RV industry. I posted on here about adding some usb outlets to the dash and in the process of taking the dash apart to gain access to the wiring behind the radio area I found no less than 3-4 types of wire connectors used to splice the wires for the radio, camera monitor and all the other systems in that area.. they used the cheapest butt connector they could and it looked like they were crimp using pliers but the most concerning was the use of actual 120v wire nuts to connect all the radio wires and most of the camera monitor wires together and itís just a huge rats nest of wire! There is no organization to it at all, when I reached in there to start moving stuff several of the wires came right out of the wire nuts with no effort at all!!
Wiring is a pet peeve of mine so Iíve got a lot of work to do so I guess itís a good thing Iím installing a new radio with Bluetooth capabilities..
Take Vacations.. Go as many places as you can!
You can always make money..
But you can't always make memories!
Beards79 is offline   Reply With Quote
light
