On my 2015 Dynamax DX3, the main slide could be adjusted AT THE CONTROL PANEL. At the back of said control module, there were several buttons that, when pressed, would cause the slide out to move in a particlar direction. BEFORE messing with anything on the ourside, I'd play 20 questions with the factory (or Lippert or a GOOD RV technician). You may well have a problem that is easy to correct; a solution that is NOT likely to cause additional problems.
