Removed the ATS and found the coil for the shore power contactor fried. Had heated up so much, the plastic around the coil melted to the point the laminated plunger could not pull in. Instead of returning it to Elkhart (4th Time) for warranty work, I ordered a new replacement ATS from Amazon and in 2 days had it fixed. So off we went, our last fall short trip for the year. Went to put out the dining room side, and with broom handle in hand, I watched the plastic chain start to bunch up instead of going down the hole like it should. Brought in back in and found a broken link again. Then, turned the furnace on and the T-stat did not work. This is the T-stat that they supposedly fixed in Elkhart last summer. Spent one night with fireplace only for heat, then headed home. RV'ing is so much fun and relaxing. Ohio has a RV lemon law and my SO has documented all the issues we have had with this coach. We are fed up.
