03-23-2020, 06:48 PM
More internal storage
For those with a Georgetown, I have a GT3 and want to share with you an addition to the internal storage space. Rails cost 500 40 inch heavy duty the draws and materials $130. As there are only the two of us I removed the seatbelts.
03-23-2020, 07:09 PM
I know those drawers are nice... because the slides are nice!
2014 Shamrock 183
03-23-2020, 09:37 PM
Very Nice!
03-23-2020, 10:05 PM
I'm sorry, you're saying the drawer slides were $500 !?!? Am I reading that right? what kind are they?
Travel Trailer: 2004 Flagstaff 25LB
New Tow Vehicle: 2017 F-150 3.5 Ecoboost, supercrew short bed FX4 Lariat
Old Tow Vehicle: 2009 Silverado 2500HD 4x4 Ext. Cab Short Bed
Travel Pooch:Sophie the Sato - Cats: Rhody and Hazy
2018:22nights / 2019:31Nights / 2020:18Nights
03-23-2020, 10:58 PM
Lowe’s
2 Pack 40-in Drawer Slide
Item #: 1689257| Model #: H.901857500
Wayne Knott
Georgetown GT3
03-24-2020, 06:33 PM
Iam confuses on the cost of what you call the rails cost $500 u said . , iam a general contractor and I can buy heavy duty ball bearing full extension draw tracks for $45 per set at almost any full service lumberyard , what’s the difference from your rails .
03-24-2020, 06:42 PM
perhaps he bought some quality rails like this
2014 Shamrock 183
03-24-2020, 06:47 PM
I don’t know as previous reply I have given the details from Lowe’s. Let me know once you have reviewed. Could be I paid too much.
Wayne Knott
Georgetown GT3
Apparently the 40” length increases the cost
Almost 500% I think Iam in the wrong business.
Thanks for sharing your pictures love the extra storage space
03-24-2020, 06:49 PM
Thanks, They make a big difference to the storage area
Wayne Knott
Georgetown GT3
03-25-2020, 08:31 AM
I’m going to do something with that space too. We are using it but it is an annoyance to remove the seat cushions. Nonetheless thinking of cutting the covers (including sanding where Georgetown did a shoddy job) and maybe hinging.
Another option would be to make 24 inch drawers and still remove cushions to access rear half for less frequently accessed stuff.
03-25-2020, 09:09 AM
I'm going to order some from these folks soon since I'm not that handy: https://www.shelvesthatslide.com/mm5...ct_Code=AM47SS
They will build the shelves to your width in 1/8" increments. If you select Blum full ext. (*extra depths) + $20.00 you can get a depth of 35 3/4". I'd like the full depth but honestly this will be good enough for us.
i'm going to try the Base Mount 4 L Brackets and secure a piece of 1/2" plywood to the 1x1 wood already there and then screw the shelves to the plywood.
I'm going with the taller shelf sides to help keep stuff from falling out as we're driving and getting underneath some place where ti should not be.
I will be keeping the seat belts so the rear drawer will need to be quite a bit narrower but we'll just adjust what goes where.
It should be about $75 per shelf.
FWIW,
Ray
2020 Georgetown GT5 34H5
03-25-2020, 10:08 AM
At $230 a pair they are pricey, but they do make a nice installation.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
03-27-2020, 08:54 AM
Very nice!
Pete Githens
Reading, PA
2019 Georgetown GT5 31R5
2018 Chevy Spark
Formerly - 2007 Itasca Navion (Sold and gone)
03-28-2020, 03:12 PM
I am cheaper, I plan to install shorter drawers to get easy access to some stuff, and leave less used stuff under the seat. I have already sanded the cover and installed the hinge on one side only.
2018 Forest River Georgetown model 31L5
Flat towing a 2019 Chevy Spark
04-02-2020, 07:30 PM
A cheap temporary solution we use is a plastic wheeled under-bed storage box under each cushion. One holds extra pots & pans, the other our computers. A pain to pull Velcro end caps off to roll out drawers, but decent $25 interim storage. Think I will look into building those drawers. 2018 369XL/DS.
04-07-2020, 06:13 AM
That's my plan as well. I've already sanded the covers. Did you stain yours? Also, what hinge did you use? Any pictures you would care to share?
Cheers,
Wayne
05-11-2020, 06:16 PM
Nice drawers, would you mind posting pictures of what it looks like inside the storage area and how it is attached inside. Thank you.
05-11-2020, 06:23 PM
Will do tomorrow
Wayne Knott
Georgetown GT3
05-11-2020, 06:33 PM
Nice work. But for $630 I'll just open my dinette seats.
2012 Georgetown XL 350TS, Hellwig front/rear sway bars, Sumo Springs, Blue OX True Center steering damper
2013 Ford Explorer LTD toad, Roadmaster Stowmaster 5000, VIP><Tow Brake
Better to have a bad day of camping than a good day at work!
