Originally Posted by KenandCarol
On my Sunseeker MH I have the propane and electric switches on the control panel...and yes, the electric one does turn on the WH. I have an Atwood water heater.
There are several different models of tank style water heaters that Forest River uses in their vast array of different RV's.
There are basically three types they use with the dual electric/propane option.
The Atwood brand will have two switches inside the RV, where one controls the propane and the other turns on the electric element.
However, Suburban has two main models, the SWDE and SWDEL, and they have different switch configurations. Both are explained in this link:
http://www.forestriverforums.com/for...ore-36197.html
So, depending on what RV you have, you could have one of three different tank style water heaters, and yours could be different than the OP's. Tbonz and Iggy most likely have the Suburban SWDE model, that only has the switch for the electric element outside on the face on the water heater.
