Old 07-16-2020, 04:23 PM   #1
tamdle's Avatar
Mystery roof leak
In the last couple months, I am having problem with the roof leak on the driver side, right above the driver seat during heavy rain. I checked all of the seals/caulking above the roof and found no where that could be leaking. I recaulked the complete roof and still have leak. Does anyone have the same problem? Any hint?
Do I need to remove all of the old caulking before putting a new layer of caulk? All I did was clean the old caulk then caulking over the old with overlap down to the roof material.
Thank!
Tam & Ha from Willis, TX
2016 Georgetown XL 352QS
2011 Jeep Grand Cherokee
tamdle is offline   Reply With Quote
Old 07-16-2020, 04:59 PM   #2
Just as confused as you
Scrapper's Avatar
Check the drivers side window seal.
Richard & Jill
Camping since 1989, seasonal since 2000
The Faster I Go, The Behinder I Get.
Scrapper is online now   Reply With Quote
Old 07-16-2020, 05:01 PM   #3
Iggy's Avatar
Front roof marker lights.
When I'm driving into a heavy rain it come in around the roof marker lights.
Did some minor sealing around lights and it never happened again.
Iggy is online now   Reply With Quote
Old 07-16-2020, 05:49 PM   #4
tamdle's Avatar
Thank Iggy and Scrapper, the leak is through some where from the roof, not on front or side, because my ceiling liner right above the driver seat is soaked with water...
Old 07-16-2020, 05:53 PM   #5
tamdle's Avatar
Okay, I just went out and look at the front of the roof, there are some LED yellow marker light... It is too hot right now to check, I will check that is couple hour when the sun set lower and not as hot...
It may be it... Thank...
Old 07-17-2020, 06:58 AM   #6
Check the o rings on the roof tv antenna it happened to me. Thanks
gailrich is offline   Reply With Quote
leak, roo, roof
