I just had my Georgetown motorhome winterized and then we had to use the coach. So I flushed the lines and then turned both hot water heaters on with the on/off switch outside. They are not heating up. I even tried turning them on Gas. Still not working. Am I missing something? Any help is appreciated. Thank you in advance.
If you turned the electric heat on while the tank was empty you probably burned up the heat element. I did the same thing myself a few years ago. You will still be able to heat with gas. Open the pressure relief valve. If no water comes out your bypass valve is closed.
On a positive note... Whoever winterized your coach might have turned off the electric heater.. there is a switch under the water heater panel by the gas inlet. Make sure after the tank is filled to turn it on.. I always flip mine off when I winterize.. Just in Case..
2013 Ram 2500 "Cummins"
2014 Columbus 340RK
Month of July in the Egg Harbor Campground, Door County, WI
5 stars
