Originally Posted by Taylorj158
I have a 2022 Georgetown 31l GT5 and on the maiden voyage. We had no hot water for 10 day's. To compound matters. The winegard did not word as well as the antenna would not pick up any signals. Finally we tried to use our cook top and the propane would not work. It has been a total disaster. The rig has 1100 miles when we left home. Not a happy camper. We have minor stuff like rivets not set and trim coming off the walls. I am not a happy camper. Before we left the main faucet broke after I opened it up from a factory winterizing. Did not get the faucet in time so I had to buy one just to go on the trip. Maybe thay was a precursor for cold showers, microwave meals and no TV. seems like dejavu all over again. At same campsite 3 years ago our new Fleetwood Jamboree mechanically broke down. But when we got it back only to camp two days, at least we had a TV and hot showers. Forest River, I had hoped you were better than this. Frustrated and disappointed camper. We waited 7 months for this? SMH.
I feel your pain, especially a 2022 - my thoughts are if they charged you a pricetag for a brand new 2022, you paid for a fully functioning RV that should have passed QC.
I'd like to offer a few suggestions that may help - as NXR mentioned, sounds like the dealership likely left the bypass in place (which is odd because they would need to system check everything before delivery to customer - this includes the water system). With the Winegard, there is a small media box installed in the cabinet directly above the sink. You should have three modes that you can adjust (TV, AUX/SAT, and Cable). Slide the switch to TV and ensure the button above it is pressed for Antenna Power (Green light should be on). The propane may be off from the dealership (this may have occurred while driving through tunnels during transport). Check the propane compartment and ensure the valve is fully on.... if you are still having issues, you may need to purge air out of the system. Do you hear anything when you attempt to run gas through the stove?
