Old 06-11-2022, 04:42 AM   #1
No backup Lights
Just noticed they arenít coming on. Easy fix?
2018 GT 369 CL
JSingleton is offline   Reply With Quote
Old 06-11-2022, 06:25 AM   #2
Kanadian Kamper
kenandterry's Avatar
Quick checkÖ..when you place the vehicle in reverse, have you verified with a digital meter that there is 12 volts at the socket?
Ken and Terry
kenandterry is online now   Reply With Quote
Old 06-11-2022, 11:53 AM   #3
I will get my hubby to go check. Thank you!
Joanne S
2018 Georgetown 369 XL
Old 06-11-2022, 11:59 AM   #4
clr
Most probity is two burned out light bulbs. Back up lights are easy to miss when one goes out and then the other bulb gives out. If a cleaning and bulb replacement does not work I would then check to make sure that I have 12Vdc to the bulb when the back up lights should be on.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is offline   Reply With Quote
light
