Old 07-03-2020, 07:34 AM   #1
kentdavido's Avatar
No Hot Water Either Heat
ID:	232987Click image for larger version
So Iím blew the water lines on rig for the winter. I remember shutting the water off to the water heaters so that I could build up the pressure on the other lines once I took out the Anirod Rods and had blown the hot water tank.
So I have no hot water in either tank or theyíre not firing up so I assume I have no water in them. I thought I was perfect when I installed the rods back in and didnít have any leakage. Can you look at the photos and see if those three valves are going the correct direction.
Help weíre out on the road.
kentdavido is offline   Reply With Quote
Old 07-03-2020, 07:49 AM   #2
Looks like your bypass valve (the one on the short pipe between the hot and cold lines) is open. it should be closed for normal operation.
Can you confirm if you have any water in the heater? What type of heater do you have (ie: propane only, propane-electric)?
2010 Wildwood XLite 26BHXL
2013 Ram Outdoorsman 5.7l
Ontherock is offline   Reply With Quote
Old 07-03-2020, 07:51 AM   #3
kentdavido's Avatar
Well I just loosens both rods and water started to come out. Weíll see if anyone has any answers.
Old 07-03-2020, 07:53 AM   #4
kentdavido's Avatar
Are you referring to this one
Old 07-03-2020, 07:55 AM   #5
Like on the rock said. The center valve, close it
2015 grey wolf 27RR
2015 Chevy 3500HD
kcmusa is offline   Reply With Quote
Old 07-03-2020, 07:55 AM   #6
Originally Posted by kentdavido View Post
Attachment 232989
Yes
2015 grey wolf 27RR
2015 Chevy 3500HD
Old 07-03-2020, 07:57 AM   #7
nomad297's Avatar
Turn the center (bypass) valve in your picture 90 degrees clockwise and you will be in business.
Bruce
Old 07-03-2020, 07:59 AM   #8
kentdavido's Avatar
Attachment 232989
We have this guy
Old 07-03-2020, 08:01 AM   #9
So there's water in the boiler now. Is it propane only or is it electric too? If so, did you have the boiler full of water BEFORE you tried to heat it with the electric element?
Old 07-03-2020, 08:02 AM   #10
nomad297's Avatar
Attachment 232990
We have this guy
It has nothing to do with anything in this picture. Just turn the bypass valve off.
Bruce
Old 07-03-2020, 08:04 AM   #11
Flybob's Avatar
Attachment 232989
Turn the middle valve 90degrees.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 07-03-2020, 08:07 AM   #12
kentdavido's Avatar
No I have the electric off.
Old 07-03-2020, 08:10 AM   #13
Reason I asked is if you tried to engage the electric element BEFORE the boiler was full, you may have damaged the element; hence, no hot water.
Does the water still feel "cold" or is it tempered somewhat?
Old 07-03-2020, 08:12 AM   #14
kentdavido's Avatar
Well I didnít turn the electric on I can try that. These worked last fall. So short of blowing out the waterlines Iím not sure what else I did.
Old 07-03-2020, 08:18 AM   #15
If you closed that bypass valve and didn't try to electrically heat a partially filled boiler, you should be OK now.
If the propane burner is working now you should soon feel a difference from the faucet.
Did you bleed all the air out of the hot and cold lines?
Old 07-03-2020, 08:24 AM   #16
Take everyone’s advice and close the bypass valve. In your first picture it is the one with a red line on one side and blue on the other. Don’t turn on the electric element until the hw tank is completely full.
2018 F 150 Supercrew 6.5 bed 3.5 EB Max Tow
Jfkmk is online now   Reply With Quote
Old 07-03-2020, 08:30 AM   #17
kentdavido's Avatar
Yes the lines are clear
Old 07-03-2020, 08:31 AM   #18
kentdavido's Avatar
You can hear it trying to fire up with that rapid clicking firing up sound but nothing.
Do I need to bleed the water tanks. Maybe thereís more air sitting in them still.
Old 07-03-2020, 08:35 AM   #19
Just re-read your posts and saw you noted "heaters" - plural.
Did you close - turn 90 degrees - the valve on each heater?
If so, should be heating up now.
Old 07-03-2020, 08:41 AM   #20
Silly questions but here goes - do you have the propane tanks on and have you bled the air from them? Did you light the stove top or run the furnace to confirm good propane supply? If not, it may take a while for the propane to purge the air from the lines at the propane water heater burner (the burner's igniter is trying to light air, not propane).
hot water, water
