Old 03-01-2018, 03:58 PM   #1
SC-RVOWNER
No Power
Hi
I have a 2014 377XL, I have one Outlet inside by the kitchen sink that has no Power and my Outdoor TV has no power? These 2 issues are located within a foot of each other so I was thinking that they are related, I checked the Fuses that are in the Bedroom and they all look good, any other Ideas of what to check? I might replace the fuses anyway, but looking for ideas.
TV
tverano is offline   Reply With Quote
Old 03-01-2018, 04:05 PM   #2
Scoundrel
HangDiver's Avatar
Maybe they are on a gfci circut that needs to be reset?
2024 Geo Pro 15TB, 400W Solar, 2 Golf Cart batteries
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller, Roadmaster Active Suspension
Wooden Spoon Survivor
HangDiver is offline   Reply With Quote
Old 03-01-2018, 04:09 PM   #3
SC-RVOWNER
I will check that out. I don't remember one being there , but I will double check.
Old 03-01-2018, 04:10 PM   #4
Fuses are 12 volt, you need to check breakers and GFI.
Decon Blue is offline   Reply With Quote
Old 03-01-2018, 04:13 PM   #5
They are on the GFI circuit. Find your GFI outlet and reset it. Probably in the bathroom. Most are
Old 03-01-2018, 04:23 PM   #6
SC-RVOWNER
Thank you HangDiver, that was the issue. The GFI in the bathroom had tripped.
Old 03-01-2018, 04:23 PM   #7
Flybob's Avatar
Outlets in RV's are generally GFCI protected. There are usually 1-3 resettable GFCI outlets that have 3-4 daisy chained standard outlets protected by them. Check outside outlet and bathroom Outlet and reset if necessary.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 03-01-2018, 07:46 PM   #8
Scoundrel
HangDiver's Avatar
Glad to hear!
power
