Old 05-10-2021, 06:33 PM   #1
No reception on TV
Recently lost reception on both tvís. Checked all connections from antenna to tv except for distribution box which I cannot find. Any advice will be great.
Ashlyn is offline   Reply With Quote
Old 05-10-2021, 06:57 PM   #2
llamb's Avatar
Over the Air channels (OTA), maybe a fuse popped on the booster?
Larry
2021 Riverstone Legacy 42FSKG
2016 RAM 3500 DRW
llamb is offline   Reply With Quote
Old 05-10-2021, 07:16 PM   #3
try running a chanel scan . both sets. light on / on booster?
Thomas ho is offline   Reply With Quote
Old 05-11-2021, 05:37 PM   #4
Where is the booster fuse located? I have a white plate on the front passenger side overhead where the DVD player and the antenna/cable/satellite selector is. The white plate has an on/off button on it that works. Is that the one?
Old 05-11-2021, 05:39 PM   #5
Already did a channel scan several times.
Old 05-11-2021, 06:09 PM   #6
Could be the wire came loose at the antenna, or the amplifier in the antenna has gone bad. Also remove the screws from the white plate and see if you can carefully get it to pull out and check all the connections for tightness on the backside.
NavyLCDR is offline   Reply With Quote
Old 05-11-2021, 06:31 PM   #7
bubbles's Avatar
If the light is coming on on the "plate" the fuse is not blown.
Old 05-12-2021, 09:46 AM   #8
Will do
Old 05-12-2021, 12:39 PM   #9
W9HAM
No reception on TV
Water got into the coax connector on the roof due to a bad seal. I fixed mine by replacing the double female F connector on the roof and replaced the coax going to the antenna. I sealed it up and it's better than original
W9HAM is offline   Reply With Quote
Old 05-13-2021, 12:32 PM   #10
2018 31L5
Source
Try checking the source input on your TV, maybe selected something other than your cable connection.
bobotty is offline   Reply With Quote
Old 05-13-2021, 02:08 PM   #11
bubbles's Avatar
This is for a GT360 and I think it is for your 2012 even though it is a 2014 drawing.
Old 05-14-2021, 03:09 PM   #12
Frank DeFeo's Avatar
Didnít see where you noted which rig you have. I have a 2017 369xl. Distribution box is located in middle cabinet above windshield. To get to it I had to remove the back panel in the cabinet. 3 of the several connectors were extremely loose.
Frank DeFeo is offline   Reply With Quote
reception
