Old 06-24-2024, 09:01 AM   #1
Norcold 2118 absorption refrigerator - convert to compressor type
My 2019 Georgetown 31L5 has a Norcold 2118X 18-cubic-foot absorption (gas/electric) refrigerator. It has issues keeping decent refrigerator and freeze temperatures, especially with the hot summer temperatures. I have installed supplemental interior and exterior fans but am still disappointed in the results.
I have been researching the heck out of doing a conversion to a HVAC compressor system – specifically, through JR Refrigeration. I never boondock, so I’m not at all concerned about giving up the propane option. I simply want to maintain safe and consistent temperatures in the refrigerator and freezer!
I have been reading on numerous camping forums about JC Refrigeration’s AC and DC HVAC compressor systems and am asking for some opinions from the group about the advantages/disadvantages of each type (i.e., AC versus DC). My Georgetown does have a 2000-watt Xantrex 807-2000 inverter and I have 2 Renogy deep cycle AGM 12 volt 100Ah coach batteries. I only have a 50-watt roof-mounted solar panel to trickle charge the coach batteries while in storage.
Given this information, could I please solicit some discussion/recommendation for going with either the AC or DC HVAC conversion kit from JR Refrigeration. Thanks in advance!
Additional information: The 12V DC system uses 11.6 amps at 12V (139 watts) and the 120V unit uses 3 amps at 120V (360 watts).
2019 Georgetown GT5 31L5
DocP is offline   Reply With Quote
Old 06-24-2024, 11:39 AM   #2
Your problem like many assembly items at FR is atrocious! If your system is like my ?8 or 10 cuft model, I literally reinstalled the area behind the 2 vents, specially the upper one. There were so many air leaks, the results were what you are experiencing. I removed the upper wall behind the vent and replaced it with 1/8" plywood completely sealing except for the area required to allow heat escape- small opening is all that is necessary. I also installed a 5" computer fan with a manual on off switch inside to add additional air flow. My freezer freezes and refrigerator cooks. 0 and 34 respectively.
ID:	301290   Click image for larger version
ID:	301291   Click image for larger version
newer is offline   Reply With Quote
Old 06-24-2024, 12:57 PM   #3
While at Amish Family rv we had our system upgraded as newer did while they were installing new axles.
We have the plywood, two computer fans and a larger squirrel cage fan which we typically just leave on.
Our 13 cu ft fridge is a pain in the rear to close the doors. Must be just right or cold escapes.
If the rv is out of level the doors are an issue.
tomkatb is offline   Reply With Quote
Old 06-24-2024, 01:36 PM   #4
Thanks for the advice and pictures!!!
refrigerator
