07-10-2020, 11:47 AM
Oil cap V-10
Anyone have part number for oil cap for Georgetown v-10. Oil neck it up close to top of engine bay. Some how it walked off.
2017 Georgetown 364TS
07-10-2020, 12:04 PM
Should be available at any parts store or Ford dealer.
2018 DX3 37TS Sunset
2019 Rubicon JLU
2022 RZR Pro 4 Ultimate
07-10-2020, 12:19 PM
I think it is special on the MH. This isn't the 1st time I read about that issue. I think I would safety tie mine when the new one is attained.
I own no MH
2017 Puma 297RLSS
07-10-2020, 12:27 PM
here is one thread... pay no attention to the comedy... unless you want to
https://www.forestriverforums.com/fo...nt-197079.html
2017 Puma 297RLSS
07-10-2020, 01:09 PM
Senior Member - Retired
Only numbers on the oil cap for my 2014 Georgetown are >PA6-(GF+M)40<
Does not look like a part number to me but that is all that is imprinted on the oil cap and it is imprinted on the end of the cap that extends into the oi fill tube.
John & Gloria Hunsaker FROG Member CA-0030-988
2014 Georgetown XL 334QS (class A with 4 slides)
2013 Smart Car TOAD
Blue Ox Aventa LX tow bar, base plates, diode kit
SMI Stay-IN-Play Duo auxiliary braking system
25' Off shore blue water fishing boat
07-10-2020, 01:15 PM
After going to 4 part stores and ordering the wrong cap, I went to the dealer who pulled up an exploded view of the engine, oil extension piece and cap. He ordered it, next day it came in.
$10
Good Luck!
2014 Georgetown 360 DS Front & Rear RoadMaster Sway Bars Sumo Springs & Safe-t-Plus Stabilizer
Koni Shocks Blu-Ox Rear Trac Bar
2020 Chevy Equinox Silver sled
07-10-2020, 01:38 PM
Yeah it don’t look Ford. It aftermarket extension of the valve cover. It’s too damn long of extension too. Lol
07-10-2020, 03:11 PM
purchased that one..... doesn't fit
07-10-2020, 04:46 PM
The cap on my Georgetown has two specific characteristics.
1. The top of the cap indicates oil to be used as does the Dorman 80991
2. There is a section of material directly under the cap prior to the start of the threads as in the Duralast 8110. The extra piece of material directly under the cap is critical for the proper sealing of the oil cap.
The above may not help, however it is all I can offer at this time.
2013 Smart Car TOAD
07-13-2020, 03:24 PM
The cap is a basic ford screw on cap. Been using it for years!
2012 Georgetown XL 350TS, Hellwig front/rear sway bars, Sumo Springs, Blue OX True Center steering damper
2013 Ford Explorer LTD toad, Roadmaster Stowmaster 5000, VIP><Tow Brake
Better to have a bad day of camping than a good day at work!
08-06-2020, 12:05 PM
Does this look like it? One I ordered for F53 doesn’t fit.
https://www.autozone.com/external-en...110/225856_0_0
08-06-2020, 12:13 PM
It does look to be the same as the one I have. Good luck!
2013 Smart Car TOAD
08-12-2020, 09:24 AM
It’s not it I’m 0 for 2 I ordered. Checking with Forest River
08-12-2020, 02:55 PM
Commercial Member
Per the head of service at Jordan Ford, who supplies our motorhome chassis, the Ford part # for the oil cap on a V10 Ford is:
PART NUMBER-GU9Z-6766-A
Hope this helps!
Chris
08-12-2020, 03:12 PM
Hope this helps!
Chris
Thanks I ordered a cap for a F53 chassis and it wasn’t right. I’m worndering if Forest River is not Installing the extension fill tub which in tune uses a different cap.
08-12-2020, 03:28 PM
Hope this helps!
Chris
That could be it. It has different part number then the F53 cap I ordered
08-12-2020, 03:40 PM
Commercial Member
Here are a couple of pictures of the oil cap you should be looking for:
08-12-2020, 04:09 PM
Thanks I’m
Try that part number
08-12-2020, 04:18 PM
Commercial Member
FYI- We are not installing any type of extension at the factory. That is a straight Ford part.
