Originally Posted by bclinton
So after leaving my RV at the dealer for 3 weeks, I finally get it back. I figured I would share what they found on my electrical issue in case others run into this. They said the wire nut had came off in a junction box underneath my dinette table. There is a plywood panel under the seat cushion behind the drivers seat. Remove the panel and inside is a junction box where the circuit coming from the rear splits to the outlets in my slide out.
Good info!
But fill out yoru signature so others will know what model you have so they will know to go to that location too, should they experience a similar failure.
PS, the signature section is in the User CP at the top of the page
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
