Originally Posted by Tsjosh
I have a 2017 377TS. I hardly use the outside awning lights as I feel they are just too bright for use at campgrounds. However tonight I was out in the RV and had the awning lights on in the driveway so the wife could see. While inside I discovered the under cabinet lights on the passenger side wouldn't turn on. After checking numerous items I discovered that these lights do not turn on if the outside awning lights are on. Is this an intentional feature/interlock or do I have a problem I need to look at? Odd it took 3 years to discover!
Maybe, just maybe, someone thought…..if you’re inside, and need lights on, then you’re probably not outside, and leaving those lights on would just be wasteful.
I can’t believe I just thought that up.
Ken and Terry
