Outside TV in 351
Hello all, Purchased my first Rv, 351DS and finally have it home. Been tent camping all my life until now. So, the outside tv is not connected to the DVD player mounted above the door. Since I have all the cabinets opened up because I needed to correct the outside radio wiring, has anyone put an HDMI splitter on the kitchen tv and run it to the outside TV? would be nice to watch DVD's outside with the kids. Seems fairly simple, just need to run the wiring through the cabinet somehow. Also, if anyone has advice I'm also trying to run power from the inverter to the kitchen TV so that it can be used by kids while driving without having to run the generator. Seems like i can splice into the residential fridge outlet and run power up to the TV. 2000 watt inverter should be able to handle both, not sure what flat panel tv is rated at but fridge is 110v at 8.5 amps would = to about 900 watts.
