Old 10-07-2017, 10:17 AM   #1
sleepybadger's Avatar
Play DVD without key in ignition
First couple times we took the rv out, we were able to use the DVD player in our front console to play movies without having the key turned in the ignition. Now I have to turn the key to get the console on. 2017 Georgetown 5 36b, it's a pioneer console. Thoughts?
sleepybadger is offline   Reply With Quote
Old 10-07-2017, 10:24 AM   #2
Wait....there's a DVD player in the front console? Is it hooked to all the TV's? We just discovered, another RVer had to tell us, about the "booster" that makes your cable clear. Our experience with watching cable, on the first three trips, was AWFUL! LOL. We're newbies to the RV world!
dcluvtohunt is offline   Reply With Quote
Old 10-07-2017, 10:27 AM   #3
Yes. I'm plugged into shore power.
Old 10-07-2017, 10:30 AM   #4
Yes it feeds all the tvs. Click image for larger version
ID:	153590. There place for the DVD is along the top.
Old 10-07-2017, 12:20 PM   #5
my georgetown xl has a switch under the radio to select power from engine or house battery. when switched to engine, the radio is only on when the engine is running or ignition switch to acc. the other will operate radio from house battery.
jrowe0521 is offline   Reply With Quote
Old 10-07-2017, 01:00 PM   #6
Going to have to go out and rest things out! Thanks!
Old 10-07-2017, 01:01 PM   #7
Test
Old 10-07-2017, 03:34 PM   #8
The “booster” is to be used only with the antenna setting. Should be off when using the cable setting.
twoclaws is offline   Reply With Quote
Old 10-07-2017, 03:36 PM   #9
Can't watch cable without it. We are talking about the one that is above the center console, not the one on the roof. I think I used the wrong word, it's just a switch, not Booster. The one on the roof is the booster, correct?
Old 10-07-2017, 06:10 PM   #10
swamprat26's Avatar
Did you have the radio switch on under the receiver?
swamprat26 is offline   Reply With Quote
Old 10-07-2017, 07:20 PM   #11
chrisbailey13's Avatar
based on your picture, the 1st switch on the left side of your console will turn the head unit on without the ignition switch being on.
2014 Georgetown XL 352QS
2013-2019 Days Camped-502
chrisbailey13 is offline   Reply With Quote
Old 10-09-2017, 08:59 AM   #12
Thanks guys. Will try it out when we get it back from the dealer. Dropped it off as soon as we got back for some more warranty work.
Old 10-10-2017, 06:19 PM   #13
Weekender
Ford1's Avatar
If that switch doesn't do it, the fuse that powers that circuit may have blown. It is located in the Battery Control Circuit box usually located under the inside steps.
Ford1 is offline   Reply With Quote
dvd
