Originally Posted by TwoFlags
I don't know. This isn't working for me. I've done it several times, but still, the slide stops in one-second intervals. And it's moving in and out at an angle. Takes a long time to get it to open or close flush.
Might I suggest that you mention
all of the symptoms the next time?
It sounds like the slide controller has gone into Emergency Jog Mode:
NOTE: For major faults, the controller will automatically enter "Emergency Jog" mode when motor movement is not detected by the controller in either direction during slide-out room activation.
When in "Emergency Jog" mode, the controller will jog both motors in the direction the rocker switch is pressed (IN or OUT). The rocker switch may need to be pressed multiple times to fully retract or extend the slide-out room.
You have a touchscreen instead of rocker switches.
If you want to continue to troubleshoot this yourself to perhaps avoid the pain, aggravation, and delays associated with dealers (which I would suggest) here's the next step:
There is a slide controller box for each slide and it is located in a basement compartment underneath each slide. The slide controller is protected by a plastic square-ish cover that is screwed to the ceiling.
Remove that cover.
The slide controller has some plugs on it but more importantly it has a red LED and a green LED. Those LEDs will blink out a specific pattern for specific faults. You need to try to run the slide while someone attempts to run the slide. (I do not know how long the lights will remain blinking after the button is released.)
Once we know the fault code being detected we know what the next steps might be.
As an aside, if I ever need to remove one of those plastic covers I am going to drill a small hole in the side facing the basement compartment door so I can see the flashing LEDs the next time without needing to be a contortionist and removing the cover. Drilling a hole with the cover removed will not void any warranty but if you drill the hole with the cover installed and drill a hole in the controller by accident, yeah, you're paying for that.
Ray
PS: Since there are different slide controller part numbers, once you have the cover off write down the slide controller part number you have and post it as well.
PPS: I attached a Lippert PDF that shows how to reset the slide controller if it gets "confused". I do not know how comfortable you will be with following that procedure but it may be of interest anyway.
