Originally Posted by Walte1fr
Yup but when the breaker is flipped back on and the thermostat is off it shouldn't kick on correct? That's the issue. Nothing on for the thermostat flip the breaker back on and the compressor runs.
You are right; that should not happen.
Please don't take offense at some of these things I would look at. You are there; it is your camper; and I have no idea which thermostat you have or are looking at.
I would look at:
1) The thermostat. What is the model? Do you have the manual?
1a) Are you using the correct thermostat for the back bedroom AC?
1b) If it is a dual AC controller, is the correct AC selected and turned off?
1c) Thermostat bad?
2) The AC itself.
2a) There are start control relays on the control board. Maybe one of them is bad so the compressor always runs when power is applied?
2b) Bad thermal fuse on the blower motor?
I am pretty much shot here. After this it is multi-meters and wire trace.
If anyone has an idea what else to look at; have at it.
