05-25-2011, 11:27 AM
Receptacle for OBD scan tool
Does anyone know where the receptacle to plug in the scan tool on an 2002 Georgetown 325 is located?
05-25-2011, 11:34 AM
CLASS "A" Senior Member
In my case it's right at the steering column close to the floor but my unit is a 2007, but should be in the same general area.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
05-26-2011, 09:46 PM
OBD ScAN tOOL
Gentelmen, I am showing my ignorance a bit but I must ask:
What is the OBD Scan Tool?
05-26-2011, 09:48 PM
OBD = On-board Diagnostics - the tool allows you to check codes in the computer if say the check engine light is on or brake light is on the dash
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
05-27-2011, 07:58 AM
Commonly known as a "Code Reader"
I still can't find the plug in. It is definitely not around the steering column. I think I have a coil pack down on my V10, the engine is missing at around 2000 RPM's.
05-27-2011, 07:42 PM
Thank you for answering my question. I find that I learn a lot from this forum. I review it almost daily.
Again, Thanks
05-29-2011, 03:56 PM
Sorry but what I thought was the port is not . There's a small black box to the right of my steering column with a cap that I can't get off. I doubt it would have a cover but I can't find it either.
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
05-29-2011, 04:05 PM
Ok now it's personal. I forced my fat butt down there and guess what I found. The port is on the right side of the steering column attached to a bracket. It's about knee height and just under the dash. It has a black cap over it that reads "CONNECTOR" there's a blue outline behind it.
I popped off the cap and there it is .
So I hope this solves the mystery for everyone. I need a beer!!!!!
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
06-05-2011, 08:32 AM
Attachment 6015
Attachment 6016
You are the MAN!!! Only if I had gotten my fat butt down there, I may have found it!!
Thanks much!
Good pics
06-27-2011, 12:29 AM
Plug was in the same place, with the same cap on it, on my 2008 350DS. However I had to remove a kick panel at knee height just under the steering steering wheel to get access to it.
I had the service engine soon light come on. Code reader says PO132 & PO152; O2 Sensor Circuit High Voltage Bank 1 Sensor 1 & Bank 2 Sensor 2.
Service manual says that the only thing that will cause this is a short to positive voltage in the cable. Since it's happening on both it would have to be higher up in the cable.
I examined both upstream O2 sensors and wiring. No obvious damage anywhere.
So I cleared it in hopes that it was a fluke. Wish me luck.
2008 Georgetown SE 350DS BunkHouse
08-20-2013, 12:54 PM
OBDII Connector location
Looks like Forrest River needs to keep up with the Ford TSBs. That is a shipping location and the motorhome builder is supposed to move it . Check out https://www.fleet.ford.com/truckbbas/non-html/Q-178.pdf
08-20-2013, 02:10 PM
Retired US Army CW4
On the new coaches, they relocated it to the exact spot where you foot or knee hits it every time you get in or out of the driver's seat.
I knocked the cover (and some skin) off several times before I "re-relocated" it up under the dash.
2014 Georgetown 329DS
Towing a 2011 Jeep Wrangler JKU w/ReadyBrake
Yorkie guard dog on the dash
