Need to remove the back panel of the cabinet over the drivers area to get access to the back side of the front cap on a 373. Has anyone else done this in the past and have any helpful hints?
On my 377, the center cabinet has some trim pieces on the back panel that have to be removed and then you can pry the back panel off. I did not replace the trim as it broke when I removed it. I used four screws to re attach the panel n case I need to remove it again. No one will ever notice the trim is gone.
