Originally Posted by lacrawgator
Do the foam mattresses make you sweat?
They should, Polyurethane open or closed cell should retain heat. The denser the cells the more heat they generally will retain as they use that heat to mold to you (memory foam). The better foams like plant based foams or latex will not retain the heat like regular poly foam (cheap) will. Latex is by far the best foam you can buy but it will be expensive and heavy for an RV. As far as so called "cool-Gel" foam, testing by Consumer Reports shows little difference vs regular foams.
Retired 2020.
46 Years RVing and no end in sight.
2018 Ram 3500 SB Limited, CC, 6.7/Aisin, 4X4, SRW. Comfort Ride Energy Absorbing Hitch.
2020 Cedar Creek Hathaway 34IK, Reese 19K Sidewinder PB.
