05-09-2022, 05:35 PM
Replacing Sofa
I have a 2014 Georgetown and the sofa is peeling. Have been researching sofa's and with the window coverings it is almost impossible to find a sofa that has the right height plus we have a fireplace and there is not much space to walk. Has anyone have this problem and what did you do?
Pauline
05-09-2022, 05:55 PM
Kanadian Kamper
Peeling “pleather” or plastic leather as we call it, is a cheap material that is used extensively in the RV business. So many people have experienced exactly what you’re describing.
This is your opportunity to change out the sofa to anything you want……as long as it fits through the door. When we had ours, we changed from the bed/sofa (which was uncomfortable in both situations) to a recliner love seat that was more comfortable, and in a pinch……I spent a few really comfy nights as a makeshift bed. You don’t have to buy RV furniture…..if there is such a thing. Real furniture works much better.
BTW…..you don’t mention what floor plan you have. Georgetown has tons of layouts. Why are you so restricted on room in yours?
Ken and Terry
05-09-2022, 07:24 PM
Hi
I have a 335ds floor plan. It has a fireplace and when the slide is closed I only have about 12 inches between the sofa and the corner of the fireplace. I only have 38 1/2 inch depth from the wall to where the present sofa is. I am having a hard time finding a sofa that will fit.
05-12-2022, 10:13 AM
You can of course replace the furniture but we chose to recover. My husband found the name under the skirt of who provided the furniture and found out they will make new covers for customers. They sent me a sample of swatches to choose from (much better material) and we have recovered all our furniture. They made the covers and my husband removed the bad material and put new covers on. Our manufacturer is Williamsburg.
05-12-2022, 10:47 AM
Originally Posted by Pauline
Hi
There are several companies that make replacement rv furniture. How long is that sofa? That's usually how they are sized. If you can't find a manufacturer's tag, a quick 'google' search for an rv sofa and the size will get you started. You might also consider checking with an dealer who sells replacement rv furniture.
If you're consider recovering, I'd probably consider a regular upholstery shop where they can renew the foam and you've got a wide choice of materials. We found that our jackknife sofa literally unbolted from the frame and we could take it in in parts. We went with an auto upholstery shop because we needed something really durable, but that's probably not what you need.
2015 Dynamax REV 24TB class C
05-12-2022, 11:00 AM
Frog-Toberfest Organizer
I have a fifth wheel but I took careful measurements and went to a local furniture store (Slumberland) and found a La-z-boy that the back would come off of and fit through the door.
2016 Vengeance 320A
2015 Chevy 2500HD LT 6.6L 4x4 ccsb Z71 trim
2012 HD Electra Glide
Andersen Ultimate Aluminum fifth wheel hitch V2
Days camped '16=43, '17=47, '18=57 '19=47 '20=47 '21=64 '22=62 '23=72 '24=0
05-14-2022, 04:34 AM
Hi
Thanks for the information. I contacted them and they only go back to 2016. I have a 2014. Thanks for your help. Pauline
05-15-2022, 08:00 AM
We replaced ours with a LazBoy reclining love seat. The back is higher than the window. But as it reclines it lowers and drops just under the window. So when you are fully reclined it is just about touching the wall.
2012 Georgetown XL 350TS, Hellwig front/rear sway bars, Sumo Springs, Blue OX True Center steering damper
2013 Ford Explorer LTD toad, Roadmaster Stowmaster 5000, VIP><Tow Brake
Better to have a bad day of camping than a good day at work!
05-15-2022, 08:10 AM
Kanadian Kamper
We used REAL recliner furniture to replace our decaying pleather bed/sofa.
I don’t remember the brand, but the back came off for easy entrance into the motorhome, and these were 10x more comfortable. And like Dodge Guy……the height of the back would drop as you reclined.
Ken and Terry
07-30-2022, 09:14 PM
I'm recovering the sleeper sofa in our 2014 Georgetown. Dumb! Dumb! Dumb! I didn't take enough pictures. Does anyone have pictures to help me piece this back together?
07-31-2022, 06:00 AM
We are replacing both the dinette and the sofa in our GT5. Standard table and 2 chairs going in and I found a very comfortable sofa at Rooms To Go that will fit through the 28 inch door. No more sleepers, but we don’t need them.
07-31-2022, 09:53 AM
I have a 2013 378xl and experienced the peeling fabric problem back in 2018 with two seater sofa and drivers and passenger seats. I chose to recover mine with pre-sewn replacement fabric from Williamsburg furniture, company whom made original furniture in my unit. I replaced fabric myself and it was not difficult. As a side note, I had no previous recovering experience. New material seems to be of better quality and has held up for four years without issues. Below is contact information at Williamsburg back in 2018.
Melody Douglass
Parts & Service Manager
(574)773-7711 EXT 17
parts@wbfusa.com
Williamsburg Furniture Inc.
2096 Cheyenne St.
Nappanee, In 46550
2013 Georgetown 378 XL
