03-31-2020, 12:58 PM
Roof Replacement Video
Very interesting look at our roofing system and why we have so many leaks
Please see the link below
Kind of disheartening
03-31-2020, 04:32 PM
Did they replace a fiberglass roof with a rubber-ish roof? Or do the older Georgetown's have rubber roofs?
I do not like how the water lays on that awning rail at all. I was thinking about notching it in a few places to let the water drain off anyways.
I try to stay a bit front-high anyway to facilitate water run-off and while it mostly works the water from the air conditioners does lay against and in that awning rail, surrounding those glopped-over screws.
I'm going to need to pull my air conditioner covers off and see how they're sealed to the roof.
I'm not sure if I'm happy or sad he mentioned the other RV manufacturers he's seen with the same problem and even on a 2019 model from someone else...
I wonder what all of that work cost.
Ray
2020 Georgetown GT5 34H5
03-31-2020, 05:26 PM
Very eye opening video. I can see us needing something like this down the road on ours. I might wanna ask them how much this would cost on our TT. Thanks for posting. I like the quality of their work. I'm sending them an email to inquire about a rough estimate of a roof replacement on ours. I realize that prices will probably go up once we need one, but, a ballpark idea isn't a bad thing to know.
2016 Jeep Grand Cherokee Overland 5.7
2020 Coachman Apex Nano 187RB Outfitter & Off-Grid
03-31-2020, 05:42 PM
What's even more disturbing....
03-31-2020, 05:55 PM
Yes they did replace the fiberglass roof with the rubber type of product that they use which was 60ml thick.
Looks like a very nice product
03-31-2020, 05:58 PM
I believe the cost was in the 10K range depending on inside ceiling variables etc.
03-31-2020, 06:38 PM
I used to work for a company that made commercial roofing products and I recognized the high-quality workmanship they did. It definitely is an intriguing idea.
I know the fiberglass panels and roof on ours is vacuum-bonded. I wonder if the older ones are that way. Either way, that video gave me some ideas of where to look closer once it warms up around here.
I think Forest River now uses Pro Flex RV Seal instead of Dicor, though. I may email them to ask even though I don't know if it's better or worse.
Ray
03-31-2020, 07:42 PM
Got a rough estimate of $5,000 to do the roof on our 187RB.
03-31-2020, 07:43 PM
If they did change sealant, that'll put me a little more at ease. Otherwise, I might be peeling off all the crap on the roof and replacing it with (edited) Novalink 35.
03-31-2020, 08:15 PM
Novalink 35 is the recommended sealant by these guys. Need to prime the roof before using this stuff. This might be a just-out-of-warranty thing for me to do. Bestmaterials.com has it for $5.65 a tube.
04-01-2020, 10:28 AM
Makes me sick to see that. Fortunately our MH was kept covered when we bought it and is kept in indoor storage currently!
2012 Georgetown XL 350TS, Hellwig front/rear sway bars, Sumo Springs, Blue OX True Center steering damper
2013 Ford Explorer LTD toad, Roadmaster Stowmaster 5000, VIP><Tow Brake
Better to have a bad day of camping than a good day at work!
04-01-2020, 11:23 AM
They've got a couple of Georgetown videos on their YouTube channel. I'm pretty sure you're doing a much better job of roof maintenance than those owners were. One of the inside ceilings had yellow spots on it and was otherwise a mess.
The mounting of those awning rails is a real WTH?, though, even on mine. They remind me of my shower sliding door tracks. The tracks have oval drain slots but they do not go to the bottom of the track nor was there a drain slot at each end.
We were getting standing water in the tracks so I took a flat file and filed the slots down about 1/8" and drilled another drain hole in one end. No more standing water and the tracks stay a lot cleaner now.
Pay me now or pay me more later.
Ray
04-04-2020, 03:32 PM
To be fair....let's come back to the new roof in 8 years after it has had very little to no maintenance. Compare apples to apples.....Dicor is on millions of RV's....are all of the roofs failing?
2017 Georgetown GT3 31B3
N Little Rock AR
04-04-2020, 03:45 PM
A couple of decades ago I used to run a distribution warehouse for a large commercial company, a subsidiary of the company I worked for. EPDM roofs, which we bought from a major tire company and rebranded, had the most warranty claims while the TPO roofs we manufactured on our own had very little problems when properly installed and pressure-washed each year . No maintenance as the ones in the video looked like meant discoloration and a lot of problems. Just keeping them cleaned and inspected made them almost trouble-free.
I think the major benefit from those folks is how they changed things to lift them above the roof and to permit greater water run-off.
The way those awning rails are mounted feels like negligence to me. Nobody builds a roof and allows water to pool on it.
Ray
04-05-2020, 07:25 AM
NXR, I did see the other Georgetown videos. Yes, they look very undermaintained. Im sure the oil changes are probably just as neglected! Makes you wonder if they are still running on 8 year old tires?
04-05-2020, 07:46 AM
I am proud that I had the RV Flex Armor roof installed on my Cedar Creek, it will last longer than I will with no Maintenance
2005 Cedar Creek 30RLBS/TrailAir Hitch/ MORryde 7K IS/Disc Brakes/ PI PT-50 EMS/ RV Flex Armor Roof
2015 RAM 3500 DRW 6.7 Cummins 3.42/ Garmin 760RV
40 Gal TransferFlow fuel tank/ TST 507
Amateur Radio W5CI 2019 Days Camping 25
2020 Days Camping 7
04-05-2020, 08:23 AM
That line should read "for a large commercial roofing company". We did roofs all over the world including stadiums and many Walmarts.
One stadium project was a white TPO roof. It went great until four years of neglect caused it to look dingy, streaked and grow stuff on it. And that's when the owners read the contract about how they were supposed to wash the roof. The said they thought rain would keep it clean. The lawyers made out on that one, again.
I actually need to have my house roof cleaned. A new roof was put on about four years ago and it's starting to get dark in spots from the trees growing over it.
It never ends...
Ray
04-14-2020, 09:10 AM
The dicor sealant seems like more of an issue than the roof. I'm going to use it while ours is still under warranty, but after that, I'm going to swith to something that will last the lifetime of the roof.
Speaking of cleaning, what does everyone use to clean under a solar panel? It's about 1" off the roof, wanna make sure the TPO under that stays clean.
04-14-2020, 12:13 PM
I read that person's comments as that improper preparation of the surfaces before applying Dicor was the real issue, his otherwise negative and unsubstantiated comments aside. He's a sample size of one and that makes for poor statistics.
I'd think that if Dicor really was so inherently poor, some enterprising RV-owning attorney would already have taken them to task.
Ray
04-14-2020, 01:07 PM
It looks like they do a great job!
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2016 Ram 3500 Laramie 4X4 6.7 Cummins Diesel
Never Enough Time Camping!!
