Old 03-17-2020, 11:19 PM   #1
Rust
Can someone please tell me if this is rust, also is the front film removable?
Thank you
ID:	225353   Click image for larger version
ID:	225354   Click image for larger version
Fidaddy is offline   Reply With Quote
Old 03-18-2020, 04:36 AM   #2
congrejoloco's Avatar
Doesn't look like it to me. Have you tried cleaning it with a regular car body cleaner/wax?
Cheers,
Wayne
congrejoloco is offline   Reply With Quote
Old 03-18-2020, 06:37 AM   #3
That just looks like staining from neglect and exposure. I agree with the fellow above, I would grab a mild polish and you can hand rub that or use a DA/orbital to quickly buff that staining off and restore the luster underneath.
You can hit a Wallmart or parts store and grab Meguiars G19216 "Ultimate Polish" for around $10 - $12 and and you should get through that in short order. After you do the polish you will want to apply a sealant, there are plenty of super easy to use spray sealants on the market now that include Turtle Wax ICE, Meguiars G190526 Hybrid Ceramic $21,99 for the large 32 oz ( https://www.amazon.com/Meguiars-G190.../dp/B06WVQ6MVR ), Turtle Wax Hybrid Ceramic 53409 for $15.99 for 16oz ( https://www.amazon.com/Turtle-Wax-53...EERGZR1T8RP4GP )
You have options.....
2019 Ram Bighorn, CC/SB 2500 4x4 6.4L/8 Speed, Max Tow 14,460 lb/2,940 lb payload.
2019 F-150 King Ranch 3.5 Eco, 12,800 lb/1,546 payload.
2020 Coachmen Apex UL 289TBSS
2019 Quality Trailers 16'x7' 7K GVWR Utility Trailer
2019 IronBull 22'x102" 14K GVWR Equipment Trailer
Larry0071 is offline   Reply With Quote
Old 03-18-2020, 06:45 AM   #4
Dodge Guy's Avatar
That is a well known failure of the protective film. Mine wasn’t that bad. I buffed mine out and then waxed it. Looks almost perfect, but years of dead bugs have eaten into the film. There are some you tube videos on cleaning it and/or removing the film. Removing it is time consuming, but ultimately the best way to go.
This pic is from last year when we bought it. Not sure if you can see it, but the bugs have etched the film.
2012 Georgetown XL 350TS, Hellwig front/rear sway bars, Sumo Springs, Blue OX True Center steering damper
2013 Ford Explorer LTD toad, Roadmaster Stowmaster 5000, VIP><Tow Brake
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
Old 03-18-2020, 10:51 AM   #5
Rust
Thank you all, didn’t look like rust to me.I will get some wax and give it a go.
Much appreciated.
Old 03-18-2020, 11:30 AM   #6
I just had the film removed. Looks like a different coach. Prior to that I tried rubbing compound, cleaners, orange gels and after several months and hours decided to remove it. Should have done it earlier
Bill M
2012 Georgetown XL 360
2011 Chevy Equinox - 2006 Chevy Avalanche
Bill m is offline   Reply With Quote
Old 03-18-2020, 11:42 AM   #7
Rust
Hey Bill,How did you remove the film?
Thx in advance
Old 03-18-2020, 12:04 PM   #8
I attempted following the suggestions from several youtube videos. Then went to a shop had them do it, cost me about 500.
Bill M
Old 03-18-2020, 12:08 PM   #9
check out this video.
I removed mine without a steamer. Temperature was around 90 deg. The trick is to pull on the film laterally. This allows the adhesive to release from the paint. If not, you will leave a lot of adhesive on the paint. Requires a lot of elbow grease to remove that adhesive.
dancort is offline   Reply With Quote
Old 03-18-2020, 12:08 PM   #10
Kanadian Kamper
kenandterry's Avatar
Thank you
Do you have a label on your rig that says “Diamond Shield” or similar?
I’ll bet you only have this problem on the front of your rig.
Ken and Terry
2018 Sunseeker 2430S with Trekker cap
and only rarely pushed by our 2017 GMC Terrain toad (4 wheels down)
Former Georgetown 330TS owner for 10 years with more mods than I can count.
kenandterry is offline   Reply With Quote
Old 03-18-2020, 12:20 PM   #11
ArubaGeorgetown's Avatar
Or put a Rhino Coating
if you can't remove or polish out - we had this done on ours.
Sorry sideways
Georgetown VE 34.1 DS
Favorite Drink: Buffalo Trace & Good craft beers with Great Cigars !!
ArubaGeorgetown is offline   Reply With Quote
Old 03-18-2020, 04:51 PM   #12
Smile Rust
I like the idea of applying a Ryno coat.Can you please tell me what it cost you?
If you don’t mind
Old 03-18-2020, 04:53 PM   #13
Rust
Kenandterry, your right the rest of the coach is fine. Only the front is like this.
Old 03-18-2020, 06:38 PM   #14
Sorry for the delay when we bought it the dealer had this done - they mention it runs between 300 to $500 dollars - also Lynx coating is another option
