RV Door Lock
Late last night, I went outside, when return, I could not open the door. Luckily, my wife still in the RV and she was able to open the door for me from the inside. Early this morning, I open up the lock and found a broken piece of white plastic interfered with the outside pull lever, but works fine with the inside lever. After removing the broken white piece of plastic, both lever now working fine. However, the piece of white plastic should be holding a certain function of the lock but now it not there anymore. Even though the door is working fine now, I certainly do not want to find out it will give me a problem in the near future while on a trip. For that, I need to buy a replacement.
Since I will be replacing the lock would cost me about $110 buck, I may well go ahead and replace it with the Keyless RVLock that may cost about twice as much and hope that it is more reliable than the Trimark that I currently have.
The question here is:
1 - Would you recommend the Keyless RVLock?
2 - What model should I get that would be a direct replacement for my 2016 Georgetown?
Thank in advance.
Tam & Ha from Willis, TX
2016 Georgetown XL 352QS
2011 Jeep Grand Cherokee
