Installed new low point drain valves on our new GT 34H5 today. Now I do not have to lay on the ground to remove the 2 drain plugs. Both can be reached through the access hole when the insulating panel is installed. Georgetown designers should take note! Also added a support for the water line coming out of the pump.
Isn't one of those drains the holding tank drain and the other is the single low point drain for cold water plumbing but will also drain hot water (no separate hot water low point drain) plumbing if water heater bypass valve is in bypass position?
Yes, 1 is the tank drain and the other is the cold water piping drain. I open a cold water faucet to allow air in. I also remove the hot water heater drain plug and open a hot water faucet to drain the hot water side. Both pictures need to be rotated for a better view.
