Old 05-24-2020, 10:38 PM   #1
Slide out issue
Georgetown 369ds xl. So storm approaching. Retracted living room slide out but forgot to remove pool floats from side wall. Now slide will not open. Suggestions please?
NovakRV is offline   Reply With Quote
Old 05-24-2020, 10:53 PM   #2
Pool noodles is what I was referring to.
Old 05-25-2020, 06:39 AM   #3
Dodge Guy's Avatar
What year? Probably hydraulic. Even with the noodles on it it shouldn’t get stuck.
BTW, why did you put it in because of a storm. Just leave it out, they are weather reaistant.
2012 Georgetown XL 350TS, Hellwig front/rear sway bars, Sumo Springs, Blue OX True Center steering damper
2013 Ford Explorer LTD toad, Roadmaster Stowmaster 5000, VIP><Tow Brake
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
Old 05-25-2020, 08:11 AM   #4
Originally Posted by Dodge Guy View Post
What year? Probably hydraulic. Even with the noodles on it it shouldnít get stuck.
2017. It is parked on a farm and with storm approaching we decided to return to town. We donít leave slides out when we are not there.
Old 05-25-2020, 08:39 AM   #5
bubbles's Avatar
Just a wag. Check this circuit breaker for the switchblade being tripped. It will be close to the coach batteries on the battery compartment wall.
Added: This is if your slide is hydraulic.
Old 05-25-2020, 09:01 AM   #6
Will check. Thank you.
Old 05-25-2020, 09:10 AM   #7
It is only the living room slide that does nothing when pushing the out/in switch. The bedroom slide is working fine.
Is there a separate circuit breaker for each slide?
Not sure if it is a coincidence but earlier yesterday we found we were unable to extend the awning. Makes no sound when pushing that out/in switch.
Old 05-25-2020, 10:04 AM   #8
bubbles's Avatar
Not sure when the bedroom slide switched to electric in the Georgetown but if your bedroom slide is hydraulic then the breaker I mentioned is not tripped. The awning is fused directly off one of the coach batteries via inline fuse.
Added: The breaker is for the hydraulic motor.
Old 05-25-2020, 10:44 AM   #9
Thanks. Will check it out.
Old 05-25-2020, 11:30 AM   #10
bubbles's Avatar
Just a thought. The ignition was off when trying the slide, correct?
Old 05-25-2020, 01:21 PM   #11
We have two and neither on was tripped. It should be covered by extended warranty so taking it in Thursday for repair if both issues.
Old 05-25-2020, 07:01 PM   #12
Yes
Old 05-29-2020, 05:19 PM   #13
Yes
Update. Awning - have to replace relay - husband took in so I donít know what that means. Not covered by ins
Slide out - had to order new motor. Covered by ins . Canít believe noodle blew motor but it could have been coincidence
Old 05-29-2020, 09:00 PM   #14
bubbles's Avatar
Should have asked up front if hydraulic or electric slide. Don't know about an awning relay unless remotely controlled. Alrighty then.
slide, slide out
