Originally Posted by armye7
Every time I go to put my slides out I blow a 15 amp fuse. Even when I'm plugged into shore power or when the generator is running, any clues what might be causing this?? fuse is located in the box under the the steps.
It sould like the hydralic pump is exceeding its amps.
1. The pump motor windings are failing and will need to be replaced
or
2. Some restriction in the hyrdralic line is making the pump work harder with max psi and the pump motor is over heating and blowing the fuse.
I have heard others mention about garbage/rubber debri in the lines from hydralic piston seals or something.
Either way time to have the dealer check things out.
