Old 04-18-2018, 07:33 PM   #1
Slides won't work
I pulled my slides in to move my 36B5, and after moving it back, the slides won't go out. I can hear a click when i press the button, but no movement. I have checked all of my fuses, and I am plugged into shore power.
Does anyone have any suggestions.
c1andc2 is offline   Reply With Quote
Old 04-18-2018, 09:05 PM   #2
Originally Posted by c1andc2 View Post
...Does anyone have any suggestions.
Insufficient power? A dead/bad battery can cause irratic behavior.
Just checking--you stated you were on shore power, and confirm AC power is on?
Battery good?
2016 RAM 3500 DRW 4x4 LB LoneStar, w/RDS 33Gal Aux tank, Timbrens, Andersen Ultimate2, SwiftHitch SH04
2018 Chaparral 360IBL w/TST507 TPMS, Lippert GC3 Autolevel, Furrion Backup Cam, Progressive HW50C, RV Airflow
chaps2018 is offline   Reply With Quote
Old 04-18-2018, 09:11 PM   #3
I was able to locate another fuse panel. I found a blown 10 amp fuse under the kitchen sink. After replacing the fuse, the main and bunk slides worked, but as soon as we pushed the bed slide button, the fuse blew. I assume I have a short somewhere in the wiring on that slide.
slide
