Old 01-21-2021, 08:06 PM   #1
Small dome on roof over driver
I have a 2019 George Town gt5 motor home, when I was inspecting the roof I found a small 4Ē clear dome on the roof over the driver seat, I bought this motor home used at a dealer so nothing was mentioned about this on the walk thru does anyone have any idea what this may be?
Tom Tom is offline   Reply With Quote
Old 01-21-2021, 08:13 PM   #2
Dodge Guy's Avatar
Should be the coax cable under it for a satellite. Should also be some cable in one of the cabinets for a satellite box.
2012 Georgetown XL 350TS, Hellwig front/rear sway bars, Sumo Springs, Blue OX True Center steering damper
2013 Ford Explorer LTD toad, Roadmaster Stowmaster 5000, VIP><Tow Brake
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
Old 01-21-2021, 10:18 PM   #3
NXR
NXR's Avatar
Yup. The other end on ours is already connected to the MovieVision switch box.
And I'm pretty sure almost no dealer could ever answer that question. Heck, some might think it's a mini-skylight.
Ray
2020 Georgetown GT5 34H5
NXR is offline   Reply With Quote
Old 01-22-2021, 03:16 AM   #4
bubbles's Avatar
Ray
If the other end of that rooftop coax is connected to the Movievision box it is connected incorrectly. That cable is the sat antenna feed and would connect to the sat receiver.
Old 01-22-2021, 09:58 AM   #5
NXR
NXR's Avatar
The splitter that we have installed from the factory is one that passes DC straight through and designed for satellite TV systems. The output of the splitter is connected to the TV port on the Movievision.
Whatev. It's irrelevant because we'll never have satellite. I have toyed with stealing that cable for a roof-mounted cellular antenna, though.
Ray
roo, roof
