Old 09-18-2020, 09:51 AM   #1
Snapped front swaybar link
Curious if anyone else has seen this happen (driver side sway link snapped clean in half). 15k miles on our 2018 GT 369XL (24k F53 chassis). Happened somewhere between Ca. And Pa. Crappy highways of course.
I did shift sway linkage to CHF position on front only. No visible contact that would indicate sway bar hit frame. Truck shop is scratching thier head and thinking this might have been a casting defect.
I'm considering resetting front CHF to factory position with new linkage just in case, but again our bus garage doesn't think that had anything to do with this snapping
Looking through many threads I've only run across one 2015 post where a guy had his bent (but bar had hit frame).
ThanksClick image for larger version
JimSt is offline   Reply With Quote
Old 09-18-2020, 10:19 AM   #2
I have seen this happen many times on trucks, although not on something as new as your rig, or as few of miles. If you don't see any evidence of hitting the frame or other suspension components, I wouldn't worry about it a lot.
What I would do is upgrade to better sway bar links. The Ford ones, although sufficient for the vehicle (or any other manufacturer) are not the "best" in my opinion. Upgrade to beefier ones through Rockauto, Adavnce, O'Reilley's, etc. They are cheap, and with a poly bushing you'll get more feel out of the upgrade.
My $0.02
Greg, Janelle, Tenley, & Ellis
2019 Palomino Puma QBSS
TV: 2015 Silverado Z71
Other toys: 2007 Rinker Captiva w/Monster tower & rack
GXPWeasel is offline   Reply With Quote
Old 09-18-2020, 01:09 PM   #3
Thanks, that helps. I have a pair of Moog links coming in thru advanced Auto so I can get to the road early next week. Not certain if they are better or not, but my local truck shop says they are decent.
Old 09-18-2020, 02:00 PM   #4
Sway bar links
Isn't that covered under the basic Ford warranty. 3years/36k miles? Maybe Forest River should have built your floorplan on a greater GVWR F-53 chassis. They start at 18K and go up to 26K no need to scrimp in the GVWR department with the chassis. I see that you have SumoSprings?????
PaulRod is offline   Reply With Quote
Old 09-18-2020, 02:55 PM   #5
Paul, may be covered under warranty, but need to travel in 5 days and isn't worth the 1.5 hour drive for $70 part and an hour labor. Tech was installing sump springs when discovered (I'd missed the actual snapping on road somehow).
I would have hoped the 24000 cassis was beefy enough, I know Tiffin uses the 26k for open roads.
Old 09-18-2020, 03:06 PM   #6
Jim the Moog's should be a good replacement choice. They probably have grease fittings too. Which by itself is a good idea. Save the broken one and the receipt and bring to an F-53 authorized Ford dealer when it is convenient for you for reimbursement. You may find that there is an on going problem or not.
Old 09-18-2020, 03:27 PM   #7
Not on a MH, but I replaced both fronts twice on my 2004 F150.
TheWolfPaq82 is offline   Reply With Quote
Old 09-18-2020, 09:00 PM   #8
Dodge Guy's Avatar
They make longer links for when you do the CHF. I don't know the numbers or application off hand, but I have seen them.
2012 Georgetown XL 350TS, Hellwig front/rear sway bars, Sumo Springs, Blue OX True Center steering damper
2013 Ford Explorer LTD toad, Roadmaster Stowmaster 5000, VIP><Tow Brake
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
Old 09-19-2020, 02:06 PM   #9
360true's Avatar
Snapped Sway Bar Link
This too happened to me. Replaced it with a Ford OEM part. About $30 at the Ford dealer. Happened at about 20k. I did CHF with Safe-T-Steer. All good for the past 10k miles.
360true is offline   Reply With Quote
Old 09-19-2020, 02:39 PM   #10
Curios: CHF before or after the link broke? Did you go with longer links/extension plates?
Old 09-19-2020, 02:46 PM   #11
NXR
NXR's Avatar
The only occurrences I've read about of snapped sway bar links following the CHF are on units using the curved links. I think that's just the 24K and 26K chassis. IT looks like yours may be curved?
Ray
2020 Georgetown GT5 34H5
NXR is offline   Reply With Quote
Old 09-19-2020, 02:54 PM   #12
360true's Avatar
After the CHF. Did not change the links, and yes mine are curved on my 2014 Georgetown XL.
Old 09-19-2020, 03:08 PM   #13
I wish people would quit using acronyms. What in the heck is CHF?
Sunseeker16 is offline   Reply With Quote
Old 09-19-2020, 03:13 PM   #14
NXR
NXR's Avatar
"Cheap Handling Fix". You move the Ford F53 sway bar link bolts from the outside hole of the sway bar to the inside hole to stiffen up the sway bar and get less rolling motion.
There's about 6,200 posts on it here, starting in 2010 when it was first discovered: https://www.irv2.com/forums/f23/chea...fix-72335.html
Happy reading.
Ray
Old 09-19-2020, 03:17 PM   #15
Happy reading.
Ray
Thank you sir for the clarification. Now I get it.
Old 09-19-2020, 03:31 PM   #16
NXR
NXR's Avatar
No problem. CHF to me usually means Congestive Heart Failure. That might be what happens when you see your link broke.
Ray
Old 09-21-2020, 07:58 PM   #17
Thanks everyone. Had the Moog swaybar links installed and shifted back to factory (outer) bolt holes just as a precaution.
Old 09-22-2020, 10:54 AM   #18
Iggy's Avatar
Interesting inforamtion.
My links are straight for my front end OEM links.
Now this is on the 242" wheel base chassis.
Shorter chassis may have different size.
ID:	239711   Click image for larger version
ID:	239712   Click image for larger version
ID:	239713   Click image for larger version
2012 Georgetown XL 378TS (Large box with wheels) 76,100 miles
Old 09-24-2020, 03:59 PM   #19
Triglide
TriGlide's Avatar
I think that the angle of the sway bay and short drag links will put too much stress on them. I would have them on the outside holes...But that's just me...
TriGlide is offline   Reply With Quote
Old 09-25-2020, 10:44 AM   #20
Dodge Guy's Avatar
Or you can get longer links and have all the benefits of the CHF.
sway
