Originally Posted by wmtire
The problem with limping it in on one tire on the rear, is that tire you are leaving now as a single will be carrying ALL the weight of that position. If you do manage to limp it in, you may want to consider then replacing that rear tire too as it could have been overloaded.
You may be being a bit generous with "could have been".
On my Georgetown with 22.5" wheels if I lose one of the rear tires the other one is overloaded by close to double. My axle weight
per side is about 7,000 lbs.
At my regular pressure a single tire can safely support 4,160 lbs of that 7,000 lb axle weight.
If I brought it up to the full 110 PSI sidewall pressure it can safely support 4,675 lbs of that 7,000 lb axle weight.
Almost a ton and a half of weight above the design limit. Yikes...
If I lose a rear tire my plan is to get pulled over as soon as safely possible and drop the rear jacks a bit so maybe that rear tire is only overloaded by half a ton. Unless I'm on a hill. Then it's bye-bye tire.
Ray
