Old 09-09-2024, 09:58 PM   #1
08GeorgetownBunkie's Avatar
Spicer 130500 Rear Differential Service Specs?
My RV has a Spicer 130500 rear differential. I'm trying to find what fluid type is needed, capacity, and service procedure. I'm coming up empty handed though. My 2008 F53 Ford Service Manual doesn't list Spicer as an option.
Name:	Spicer 130500 Rear Differential.png
ID:	303810   Click image for larger version
Name:	Service Manual Rear Diff.png
08GeorgetownBunkie is offline   Reply With Quote
Old 09-10-2024, 05:53 AM   #2
Spicer is the name Dana uses for differencials.
Twinboat is offline   Reply With Quote
Old 09-10-2024, 08:17 AM   #3
realshelby's Avatar
Twinboat is correct.
The specs you list should cover your motorhome.
There should be a tag somewhere on the axle telling you which model Dana/Spicer axle assembly you have. But regardless...be sure it is level and refill with the recommended lubricant until it runs back out the fill hole. That insures the level is correct.
2023 GEORGETOWN 36D7
realshelby is offline   Reply With Quote
305, 500, service
