Old 07-29-2024, 06:01 PM   #1
squeak in floor
The kitchen area has a squeek that is about 2 ft wide. How do I get rid of it without putting some screws thru the lino floor?
PDBaller is offline   Reply With Quote
Old 07-29-2024, 06:03 PM   #2
bikendan's Avatar
Moved thread from the General Tech and Repair section to the Georgetown sub-forum for better help from other Georgetown owners and possible factory support. Also since the OP's questions are specific to a Georgetown product.
Old 07-30-2024, 09:23 AM   #3
Commercial Member
PDBaller,
Can you provide more info.... Year, floorplan?
Cdefrees is offline   Reply With Quote
Old 07-30-2024, 11:18 AM   #4
2006 Georgetown 35'
Old 07-30-2024, 12:15 PM   #5
Commercial Member
I would call our service at 574-206-7600 and ask for Georgetown service. They might be able to give you some ideas on how to fix. Hope this helps? Safe travels
Old 08-03-2024, 03:14 PM   #6
I called and was told the best way to rid the squeek is to screw the floor down. Patch over with fix all and relay the floor with new lino or tile. Was hoping for an easier fix as flooring is not my forte'. Well, it is what it is.
Old 08-03-2024, 04:42 PM   #7
NMWildcat's Avatar
Have never had an RV that didn't have a squeak in the floor at some point. Sometimes the squeak will go away, and other times it moves. I did put in some screws while chasing a squeak in one unit. Unfortunately, the squeak just moved.
Now I just live with them
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
NMWildcat is online now   Reply With Quote
Old 08-05-2024, 09:34 AM   #8
Commercial Member
Maybe try a shim between the floor and truss from underneath? Just a thought?
floor
