Old 09-16-2020, 09:40 AM   #1
Steps
Kwikee steps open up over night. Was concerned on last trip so removed fuse while traveling. Steps worked fine while camping, came home and steps retracted like they should but were down the next morning when I ck on rv. Open and closed door and they went up stayed up all day, next day down again.
loyda is offline   Reply With Quote
Old 09-16-2020, 11:08 AM   #2
Iggy's Avatar
Look at your screen door magnet.
Over time the screen door can move more or even out of shape.
I would look at the location of the magnet on the screen door and the contact assemble.
It may be the gap between the two are getting too great and needs adjustment or
maybe you just need a stronger magnet on the screen door.
Test and see.
You do know that the steps go in automatically when you start your engine.
Also do you have the step switch on or off when parked at a campground.
You should have the switch off when driving.
2012 Georgetown XL 378TS
Facebook Georgetown Owners Club
Old 09-21-2020, 04:34 PM   #3
Iggy's Avatar
Well did any of these ideas help?
Old 09-21-2020, 05:12 PM   #4
This happened on my initial drive home after PDI. It was crazy. It happened on the Dames Point Suspension Bridge in Jacksonville! It wasn't just the stairs. The door opened and the stairs too. It was a rude awakening to the RV industry. Long story, but I adjusted the door that the Factory never did to ensure it would lock shut.
270S is offline   Reply With Quote
Old 09-21-2020, 06:45 PM   #5
We are going to try a few things this trip. Will let you know the out come.
Old 09-22-2020, 09:03 AM   #6
Iggy's Avatar
Well if the door/screen door opens the step goes out.
It's all controlled by the screen door that holds the magnet.
Make sure you slam the door closed.
You can turn off the the override switch for the steps and see if the steps stay in while engine is running.
Just live and learn.
Old 09-22-2020, 09:42 AM   #7
This incident was 3 years ago after leaving the dealer after doing a full day PDI! I know what I'm doing. Not a newbie to RV crap any more. I do not give the industry the benefit of the doubt any more like I did when I first purchased.
A real PDI will take 4-5 days. You can NOT ASSUME anything is a given or done correctly. Every single item needs to be checked before you pay the balance and leave, or you are Scre^^ed!
My First & last RV. I have fixed over 70+ defects myself except the R&R on the windshield! It is very usable now, but still design defects will happen over time. I'm working on the water leak that just appeared - probably due to CA clearance lights.
I feel for the majority of RV owners incapable or unwilling to fix their RVs themselves and rely on God forbid warranty or after the fact places like CW. It makes owning a boat seem like smooth sailing. That's saying something.
Old 09-22-2020, 02:48 PM   #8
I fixed the problem. Magnet on door to close to magnet on jamb. How would of thunk.
Old 09-22-2020, 04:21 PM   #9
bubbles's Avatar
Just a note. The only magnet is the one on the door. The item on the jamb is just a switch that is normally open (door open) and closes (door closed) to supply a ground to the steps controller.
Old 09-22-2020, 07:57 PM   #10
I was surprised the magnet could be to close that it would not work the switch or ground
steps
