Old 03-13-2018, 03:06 PM   #1
Scootermae's Avatar
Steps Don't Deploy Right
My steps won't work until I crawl in and start the engine, can anyone help me. Georgetown 35DS
Bobby, Sheri, and Daisydoo
Scootermae is offline   Reply With Quote
Old 03-13-2018, 03:44 PM   #2
Denver, CO
garbonz's Avatar
I don't have a Georgetown but most rigs have a relay that will deploy the step whenever the door is opening. I would guess that yours is broke.
2017 Fuse 23T
Old 03-13-2018, 07:19 PM   #3
bubbles's Avatar
What do you mean "won't work"? Won't extend/retract/when etc. Your header says deploy and if the door is open when the engine is started it sounds like a low battery charge.
Old 03-13-2018, 07:31 PM   #4
Kanadian Kamper
kenandterry's Avatar
Scootermae.....
Do your steps ever work properly?
Is your rig in storage away from having the power cord connected? I’m thinking your might have weak house batteries.
Have they ever worked properly?
Ken and Terry
2018 Sunseeker 2430S-CD, nicely modified and carried by a 2017 Ford E450 Sport with 6 speed Triton V-10
kenandterry is online now   Reply With Quote
Old 03-14-2018, 11:36 AM   #5
jk510's Avatar
Is your master power switch off?
Joel K
2013 Coachman Mirada 29DSSE
jk510 is offline   Reply With Quote
Old 03-18-2018, 01:52 PM   #6
Broken Steps
I had a similar problem last year with my 2015 Georgetown. Oiled the joints, filed sharp edges etc. The steps still would bind "sometimes". Found out at the Frog Rally that the metal support on the upper right side was cracked. They promptly sent a man over, with all the welding and grinding equipment, and fixed it onsite.
Look carefully along all moving parts, as well as the welded supports for integrity. You may need some other eyes to assist. Use a small crowbar to check the welds as they will close up to near perfect. Good luck
weatherguru1 is offline   Reply With Quote
Old 03-19-2018, 04:07 PM   #7
tamdle's Avatar
If you step only works when you turn on the engine, then very possible that your house battery is too low. When you started the engine, the charger put the full charging voltage on your battery lead and that provide the full power to the step motor, that was why it work correctly when your engine was on.
That said, you may want to plug in your rig the shore power so it would charge your battery fully, then your step will be back working normally.
However, since you have depleted your battery too low, the chance is your battery life may not be so good to hold the charge anymore, so don't be surprised that your battery will deplete quicker than before.
Good luck and have a great day.
Tam & Ha from Willis, TX
2016 Georgetown XL 352QS
2011 Jeep Grand Cherokee
tamdle is offline   Reply With Quote
Old 03-22-2018, 04:35 AM   #8
Ekw4156's Avatar
Adjust the screen door buy pushing bottom in and pulling top out slightly....sometimes it is not hitting the sensor
Ekw4156 is offline   Reply With Quote
