The rear spring upper brackets will not fit per instructions because of interference from vertical column which is welded 3' over frame. See photo. (I don't think the shield to the left of the column is a problem).
I've read this is a problem in some 2013-14s because of the location of the column.
Has anyone made a modification or otherwise found an alternative way of fitting rear sumos under these circumstances? I have emailed this question to Supersprings and will post their response when received.
