05-11-2018, 12:18 AM
Sumo springs vs sway bar
Any thoughts
05-11-2018, 12:42 AM
Set your WDH right and forget about the rest!
My response beats yours 4.5 words to 1!
2017 Forest River Surveyor 247BHDS...
...Tugged by a 2016 F250 XLT FX4 SuperCrew, Shortbed 6.2L, 4wd, 3.73...
...Joined with a Husky Centerline TS 800-1200lbs WDH
05-11-2018, 01:01 AM
What is wdh
05-11-2018, 06:26 AM
Originally Posted by vanderwerff
What is wdh
Don't mind that post they think you are towing a trailer.
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
05-11-2018, 03:38 PM
This is one of the most common questions - search is never used, it should be removed.
The industry is so ____. You need everything. I added a rear sway, Q4 Sumos, and a steering stabilizer. ALL ARE REQUIRED. The CHF is for those that have no $ (not their fault) or refuse to part with it (TF). The most significant change was the steering stabilizer, without it, I would have left RVing. Costs apx $2-3K P&L
05-11-2018, 06:02 PM
Mine came with a rear sway bar. The best fix was better shocks and a track bar for the rear. Those changes made the most out of the ride and control. One hand steering if I choose. Also came with rear air bags.
05-12-2018, 06:38 AM
I wasn't clear enough - The rear sway bar I added is a SECOND rear sway bar in addition to the one that is already standard. The fixes I described are for Class A RVs with the pathetic Ford F53 Chassis. FYI, mine came standard with Bilstein Shocks and Goodyear tires, nothing bad there. That is the only positive thing I have seen from FR in any of their construction components.
05-12-2018, 02:17 PM
I installed sumo springs front and back as well as roadmaster steering stabilizer , this made a major difference , haven’t ruled out adding second rear sway bar
05-13-2018, 10:45 AM
The second rear sway bar helps to prevent movement with high winds.
06-23-2018, 11:55 AM
I ended up adding sumo springs front and back. Then the road master steering stabilizer, camper handles 100 times better.
06-24-2018, 09:05 PM
I added the Safe-T Plus Steering stabilizer was going to add the Sumo Springs, but they would not fit my model coach (apparently, I have an extra bracket in the rear that interfered with installation). bot the Stabilizer made a WORLD of difference. much easier to drive, pass, and be passed. Plus, wind doesn't push the coach around much at all.
2014 Georgetown XL 352QS
2013-2019 Days Camped-502
06-25-2018, 05:39 PM
Steelhorzz
I have a '12 GT 360.
I added Sumo springs to all 4 corners, steering stabilizer, and did the CHF. Vast improvement in drivability!! I just swapped out the OE Bilsteins for new ones, (at 40k it was starting to become a "rocking horse" when crossing bridges). Everything is great now!!
2012 Georgetown 360DS Fire Mist
2007 PT Cruiser Auto-stick (4 wheel tow)
Remco Trans Pump /Super Springs Sumo Springs
Blue Ox Tow System / U.S. Gear Unified Tow Brake
06-25-2018, 06:52 PM
Can you share what the Sumo Springs ran for you?
2017 Georgetown GT3 31B3
N Little Rock AR
07-04-2018, 02:47 PM
Sorry what is CHF?
07-04-2018, 03:08 PM
Steelhorzz
CHF
Originally Posted by rcampli
Sorry what is CHF?
"Cheap Handling Fix"
You loosen the sway bar links on the front and rear sway bars and move them to the next position, (hole in the sway bar).
Then you retighten them .
It shortens the movement of the sway bars and makes the chassis "stiffer". Less sideways motion.
It works pretty well.
07-04-2018, 03:11 PM
Steelhorzz
Go to
www.sdtrucksprings.com
07-04-2018, 08:42 PM
07-04-2018, 08:43 PM
07-04-2018, 08:51 PM
Or, for those waiting for a deal, the manufacturer sells them 25% off from Black Friday to Christmas.
Www.supersprings.com
A friend paid under$900 total for his under 26k class a.
Just glad to get away
07-09-2018, 07:36 PM
I wonder why the factory doesn't automatically do the CHF.
