06-23-2022, 10:42 AM
#41
Commercial Member
Originally Posted by turnski10
Actually mine is not on the F53 chassis , it's on an F 550 chassis which is my issue I'm coming to find out. Different gvwr than it's larger f53 motorhome chassis.
We don't built an the F550 that I am aware of, that is a truck chassis??
06-23-2022, 11:26 AM
#42
21Gt7
Well I have the invoice in my sales documents, and confirmed it with Ford Pro care..
06-23-2022, 12:28 PM
#43
Commercial Member
pic?
06-23-2022, 02:50 PM
#44
21Gt7
I will take a pic of the chassis/ build sticker when I get home today.
06-23-2022, 07:20 PM
#45
The F53 is based on the 550 chassis. Just no cab and only a radiator support. I’ve done research looking at upgrading the hitch and came to find this out from several sources. As well as measuring and looking up various components.
2012 Georgetown XL 350TS, Hellwig front/rear sway bars, Sumo Springs, Blue OX True Center steering damper
2013 Ford Explorer LTD toad, Roadmaster Stowmaster 5000, VIP><Tow Brake
Better to have a bad day of camping than a good day at work!
06-24-2022, 07:33 PM
#46
21Gt7
F550 order sticker
Ok explain this?
06-24-2022, 08:25 PM
#47
Commercial Member
Well, my guess would be covid shortages and they just used whatever paper they could find, but you can look at their VIN decoder to figure it out.
https://www.fleet.ford.com/content/d...-VIN-Guide.pdf
Position 5,6,7. ALL F series vehicles begin with an "X". F550 would be X5G if it was 4x2. "X5H" if it was 4x4
Yours shows F5D which is a Ford stripped chassis (incomplete vehicle). Not sure how many parts are the same. I was told suspension was different, but who knows.
You can also look at digit 11 (assembly plant). Yours is "0" which is Detroit.
The F550 is built (someone can correct me if I am wrong) in Louisville, KY and the bigger ones, 650 and 750 at Avon Lake which would be "D" or "E"
Not saying they don't share some parts...just saying that we don't ever order an F550, they are always coded as F53 (as far as I have seen).
Also came across this, but, its the internet, so who knows how accurate. Seems to support the VIN coding however.
https://www.irv2.com/forums/f23/diff...body%20builder.
And this from a Ford site which might be more reliable.
https://www.ford-trucks.com/forums/1...-and-f550.html
06-24-2022, 08:26 PM
#48
Commercial Member
And on further reading it seems like Y2KW57 seems to know his stuff in that Ford Forum post.
06-25-2022, 07:08 PM
#49
21Gt7
Everyone is right until their not, but good to know your so up to date on decoding Vin #s from ford, it's a good skill to have.
06-27-2022, 08:23 AM
#50
Commercial Member
I'm not so sure I am good at it, I just read their VIN decoder that I posted the link to, which I found via google.
So if anything, it is just my typing skills. 60 words a minute, about 30% accurate.
06-27-2022, 08:47 AM
#51
I've seen many other people post that same F550 sheet for their F-53 and per this post: https://www.irv2.com/forums/f23/2000...is-547346.html
Ford has been doing that for over 20 years. That fellow has a 1999 F-53 chassis with an F550 spec sheet. My guess is the F-53 is essentially an F550 without the cab and body, hence the "incomplete vehicle" code.
Did you know Ford does not actually make the F-53? It's been made by a contractor, Detroit Chassis, LLC for at least a decade.
Hmmm, that picture looks awful familiar.
https://www.detroitchassis.com/produ...lling-chassis/
Ray
2020 Georgetown GT5 34H5
11-17-2022, 08:57 AM
#52
This thread being closed pending further site team review.
2011 Flagstaff 831 RLBSS
