10-03-2017, 03:30 PM
Sway bar
Got rear sway bar installed..Not diffocult except breaki g loose the 15/16. Bolts on the crossover for the shackle brackets..With a little help from a hammer they came loose. Air tool didn't do it..Took a short test drive and can tell a big difference.
2017 Georgetown 329S
Toad 2015 Toyota Tacoma
10-03-2017, 03:36 PM
Nice when a project makes a difference
Retired Navy
2016 Flagstaff 26 FKWS
10-07-2017, 07:38 PM
I installed both front and rear on Friday afternoon. Front was installed in about 45min start to finish using only hand tools, including taking pics. Took out for test drive and notice quite an improvement. Brought back and installed rear. Used impact for that job and made for a lot easier install. The crossbar bolts were a little stubborn, but all came loose with impact (big impact though!). What a difference that made! No more push steer from semis and the rocking is all but gone. Felt much more glued to the road.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
10-11-2017, 10:02 AM
Ordered front Sumos yesterday..
10-12-2017, 07:06 AM
After looking at your pictures some more, my rear sway is quite a bit different than yours. I had to undo the U-bolts and bolt a 1/2" plate to the bottom of axle brackets. Then the sway bar brackets bolted to it. Must be the difference in frame weights. I thought of adding Sumos in front, but I wasn't convinced they were the solution I was looking for. Let us know your thoughts after install.
10-12-2017, 08:38 AM
Mine is a 20500 lb chassis..not a difficult install. I am hoping the front Sumos will stabilize my rig sufficiently.
10-13-2017, 07:06 PM
Installed front SUMOS today..Can feel a difference..
10-13-2017, 07:47 PM
Front Sumos.
11-23-2017, 12:52 PM
Seasoned Camper-MH newbie
Aqua man, what product(s) did you install?
11-23-2017, 12:59 PM
Front and rear Sumos..Rear sway bar..Saf T Steer.
11-23-2017, 01:18 PM
Ditto on my 270S!
11-23-2017, 07:23 PM
Thanks- found sumos, but hard time finding anything like safe t plus or saf t steer in a rear sway bar.... every search leads me to a shock. Can you give more info, please?
11-23-2017, 08:40 PM
The saf t steer is a shock that goes on the tie rod..I probably left out a comma
11-24-2017, 10:26 AM
Got it now, thanks. Front safe t steer, rear stab bar, and sumos all around!
11-24-2017, 02:34 PM
Rear SWAY BAR..not stabilizer bar.
11-24-2017, 05:17 PM
I installed the front and rear Roadmaster sway bars. The front replaces the stock sway bar and the rear is an auxiliary sway bar.
