Old 02-06-2024, 11:42 PM   #1
Tell me your Georgetown enhancements
So mine is a 2009 fr georgetown 350ds, 70k miles, 2nd owner. We love it, here are our mods;
Ok here’s my list of mods for 2007 fr 350 georgetown in order of benefit.
1-hellwig upgraded front and rear swaybars - it rides like a city bus now. No more body roll
1a-handmade custom center console to hold travel blankets, phones, water bottle, snacks between front seats - sits on top of engine cover
2a-replace queen mattress with standard high quality mattress
2b- bed slideout bracket broke - had to have it rewelded
2-swap out old crt tvs for smart tvs - probably deleted 40 lbs right there
3-ejected the sleeper sofa and dinette, replaced with 2x jacknife beds, much more practical for us. Maybe not for you.
4-ejected 3rd seat behind front passenger seat, installed minifridge inplace
5-built brackets to move front passenger seat 3" closer to the center of the rv
6-slung a 6” pvc pipe under the rear of rv to store a telescoping flagpole
7-air horn
8-weboost lte/5g signal booster. Works great when it works
9-3x leveling jacks replaced due to leaks
10-10x spark plugs replaced due to miss fires - 2 were cracked
Thats about it…
dowend is offline   Reply With Quote
Old 02-07-2024, 10:19 AM   #2
NXR
NXR's Avatar
Too much, as I mentally added up the costs a few minutes ago. Thanks for that.
Ray
2020 Georgetown GT5 34H5
FACTORY OPTIONS
Power overhead bunk
Convection microwave with oven
Dual pane windows
Sliding cargo tray
Splendide 2100XC combo washer/dryer
OWNER ADDED
Safe-T-Plus steering stabilizer - June 2019
Front and rear Maxxair 7000K fans with remote control - June 2019
Shroud over the half-bath crank-up vent - June 2019
TST 507 TPMS with remote repeater - July 2019
RV SnapPads on all jack feet - July 2019
Progressive EMS-HW50C hard-wired system with remote display - July 2019
Garmin RV 785 GPS/Dashcam - July 2019
ARP Fridge Defend with lower vent blower and internal blowers - August 2019
SuperSteer SS-401 rear trac bar - September 2019
Koni FSD shocks - October 2019
Internally-mounted Hughes Autoformer RV220-50SP - October 2019
1/8" stainless steel "slide skis" installed under warranty on all slides - June 2020
Power outlet and dual 2.1 amp USB outlets to the left of the driver - July 2020
Roadmaster Nighthawk 8,000 lb illuminated tow bar - July 2020
Roadmaster 4" drop 10,000 lb dual hitch adapter - July 2020
Two Blue Ox anti-rattle tow bar adapters - July 2020
Demco CoachLink remote braking display - July 2020
Sliding shelves under each dinette bench seat - July 2020
Roadmaster supplemental rear sway bar, 1 5/8" - October 2020
2 ea. Micro-Air EasyStart 364's, one on each roof unit - May 2021
Lippert Friction Hinge kit for the entry door - June 2021
Vista Shade, zippered, on rear awning - July, 2021
AGM house batteries, 200 minute Reserve Capacity - September 2021
Suburban stovetop cast iron grate - May 2022
CatStrap catalytic converter anti-theft device & CatEye motion alarm - May 2022
Dynamat Xtreme and Hoodliner doghouse insulation - July 2022
Dometic 310 Slow-Close toilet seat in rear bath - July 2022
Original Mattress Factory Orthopedic Pillow Top mattress - August 2022
Bauer EM Bluetooth keyless entrance door lock - October 2022
JC Refrigeration (Amish) Fridge Cooling Unit for Norcold 1210 - March 2023
Installed valves on the Fresh Tank Drain and Low Point Drain - September 2023
Replaced the Jensen XRV10 dash radio/camera display with a Sony XAV-9500ES - October 2023
Replaced both RVS RVS-MV2(RL)B10-A side cameras with Voyager VCAHD140(RL)WT cameras - November 2023
Replaced the main living area Summit 39" TV with a new Samsung 43" CU7000 TV - January 2024
Installed safety chains on the propane tank to protect against a mounting failure - February 2024
NXR is offline   Reply With Quote
georgetown, tow
