04-26-2019, 12:36 PM
Tires have cracks - how safe are they?
Hi All,
I bought these tires 5 years ago and drove about 8,000 miles on them but I did not take the RV out for about 1 year and when I went yesterday to check it out I notice my tires have cracks on them.
How safe are they with these cracks?
It cost a lot of money to replace all 6 so I’m hoping I don’t have to unless it’s a safety issue then for sure!
2008 Georgetown 370ts XL
04-26-2019, 12:40 PM
That is dry rotted. They are not safe at all in my opinion. Can blow out at anytime while on the road. I my self would not trust them on any trip. Me my first stop would be a tire shop. But that is just me.
04-26-2019, 12:41 PM
Broken Toe
How safe are they?
Not at all.
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
"Camper" 2016 Rockwood Signature Ultralite 8329ss
"Casper" 2017 Ram 2500 Laramie Diesel
..ProPride 3P Hitch - "Yeah. It's worth it."
04-26-2019, 12:44 PM
That, and the fact they are 5 years old would cause me concern.
04-26-2019, 12:56 PM
I had a set of Michelin tires do the same thing a few years ago and they replaced all 5 of them.
Even though they're five years old, I'd contact Michelin and see what they say about them. You might be pleasantly surprised, and even if they do nothing, you're no worse off.
Gotta go campin!
04-26-2019, 01:27 PM
Problem?
Only need to worry if you are concerned about blowouts.
2020 Rockwood Ultra Lite 2707WS
2020 Chevrolet Silverado 2500HD Crew Cab LTZ Texas Edition Duramax
2019 Chevrolet Silverado 1500 Crew Cab with MAX Towing and Texan pkgs.
2019 Mid Year Rockwood Mini Lite 2511S
2016 Rockwood High Wall HW276 (2016 - 2018)
04-26-2019, 01:41 PM
I would not want to be driving behind a trailer with tires that look like that.
2015 Solaire 201SS
2015 GMC 2500HD Duramax
04-26-2019, 01:43 PM
I love Michelin tires and use them on all my trucks, cars, and motorcycles. However, in my experience they age out and suffer catastrophic failure earlier than other tires. I don't keep them at all past 5 years, even without cracks.
04-26-2019, 01:50 PM
Michelin Chart for cracks. Hope it gives you some guidance.
2014 Sportscoach Cross Country, 361BH
04-26-2019, 01:52 PM
bloodybill
Definitely not safe
Highly recommend you don’t drive on them
Save a life
04-26-2019, 01:56 PM
Call your insurance provider and ask them if they will pay for an accident that was caused by bad tires.
04-26-2019, 02:02 PM
I run Michelin's on two trucks. They made me crazy. Within I couple years they start to show that surface cracking on the side walls. Unless they are becoming misshapen I bet they,are fine. Michelin will say, safe for ten years if pressure is maintained. If you are worried, have them inspected by a Michelin truck tire dealer. If that doesn't reassure you then the next level of inspection I understand is to pull one off the rim and look at it.
04-26-2019, 02:10 PM
Those should still be safe for a year or two. I called Michelin a year and a half ago on my tires that were worse than yours. They said that is normal. Unless you can see the cord don't worry. Yours looks like surface cracks. Mine are over 7 years old, I still have mine. I do plan on replacing them this year but not worried.
Tires are good for 7 to 10 years. Depends on how they have been taken care of.
I will say when I called Michelin they agreed to replace just 1 tire that I insisted on but I had to pay a prorated cost.
Bottom line is, if you have the money, you don't know how they were taken care of and you just want peace of mind then buy new tires.
Only a tire professional will be able to brake down the tire and inspect the inside to give a better judgment than me.
2013 Georgetown XL 378
2008 Honda CR-V
04-26-2019, 02:12 PM
That’s the outside of the tire which is made out of a harder rubber so it tends to crack . The outside is not structural.! ! I have driven many tires like this as some have a higher tendency to do this depending on the composition . I am sure you will get many warnings about this so you will have to make you own choice .
04-26-2019, 02:14 PM
04-26-2019, 02:19 PM
It’s always the Michelin’s that dry rot like that! Mine cane with Michelin’s. However if I had to do $6000 every 5 years in tires I wouldn’t have a class A!
I would go with a different brand!
2012 Georgetown XL 350TS, Hellwig front/rear sway bars, Sumo Springs, Blue OX True Center steering damper
2013 Ford Explorer LTD toad, Roadmaster Stowmaster 5000, VIP><Tow Brake
Better to have a bad day of camping than a good day at work!
04-26-2019, 02:29 PM
Tires
Cost to replace will be a LOT less than repair from blowing a tire. I agree this is dry rot, not safe.
04-26-2019, 02:33 PM
Run them....
with Tire Minders...
Brother Les
04-26-2019, 04:02 PM
[]That’s the outside of the tire which is made out of a harder rubber so it tends to crack . The outside is not structural.! ! I have driven many tires like this as some have a higher tendency to do this depending on the composition . I am sure you will get many warnings about this so you will have to make you own choice .[/QUOTE]
I will have to disagree with the rubber on one side is harder than the other. That would mean tires can only run in one direction and the other side, if softer will wear faster.
This is common on Michelin tires per other forums I am a member of. As one poster said, call Michelin and ask. Their answer will probably be that they are O.K. to get out of replacing them.
2013 Crusader 330 MKS
2013 Chevrolet Silverado LT 2500 D/A
