07-04-2019, 10:30 AM
Tow Haul
I drive with tow haul on all the time. We have a Georgetown GLI5 with the V 10 and I believe 6 speed transmission. My question is if 1st gear on the shifter is the same as continuing to depress the brake to gear down on declines. My first thought is first gear is first gear no matter. Also can that engine handle 4500 rpm or higher for a couple miles either climbing or descending.
07-04-2019, 10:41 AM
You may manually select first gear but the Powertrain Control Module will override any driver inputs to prevent damage to the engine. In otherwords, you might want first but the PCM decides second is better. Driver inputs on throttle and transmission are technically "suggestions", the PCM has the ultimate authority on driver inputs..
4500 rpm is fine for the Ford based V10.
2018 Ram 2500 Tradesman, CTD/CC/SB/4X4/Equalizer WDH
2019 Forest River Surveyor Legend 19BHLE
07-04-2019, 10:46 AM
Kanadian Kamper
Not sure why you have the tow/haul activated all the time, but I guess it doesn’t really matter. You didn’t say if you’re towing all the time.
As far as 4500RPM for a couple of miles.....I’ll let others chime in on that. How big are these hills/mountains? Is this because you’ve got the cruise control engaged or are you in charge of the gas pedal? If you’re revving that fast regularly, stay on top of monitoring your engine oil, engine temps, transmission temps etc etc.
Ken and Terry
07-04-2019, 01:36 PM
I’m thinking 7% grades. I don’t use cruise control in hilly or mountain areas and control by foot pedal. The slower I can descend the better for my wife. Did not realize there was a PCM that over rides the driver
07-04-2019, 02:10 PM
Tow haul should always be activated! Why because the chassis always has a load on it! And it helps with braking. These motors love to rev and on my old 02 V-10 Excursion with TT I was at 18k lbs combined and the engine would routinely see 4K rpm in the mountains and never complain. Not sure on these new 3 valve V-10's, but I would assume they are similar. I may get a tune from 5 star tuning to help with the shifting duties. It will also hold a gear longer. It's a huge improvement over the factory programming!
2012 Georgetown XL 350TS, Hellwig front/rear sway bars, Sumo Springs, Blue OX True Center steering damper
2013 Ford Explorer LTD toad, Roadmaster Stowmaster 5000, VIP><Tow Brake
Better to have a bad day of camping than a good day at work!
07-04-2019, 08:16 PM
Here is a document that explains Tow Haul Mode and what it is used for and how to use it.
07-21-2019, 12:38 PM
I use tow/haul all time as well. Mainly for breaking purposes. On my 2017 model it don’t change the shift points which I like. I’ve had my rpms around 5k range doing down hill.
2017 Georgetown 364TS
07-21-2019, 04:24 PM
We recently returned from a trip to Arizona. On some of the mou tain highways it seemed we were doing 42oo rpm uphill and down!
2017 Georgetown 329S
Toad 2015 Toyota Tacoma
