Water pump problems--Shurflo 4008
I've read a lot of forum posts about the problems with Shurflo water pumps, but none exactly like the problem I'm having...hoping someone can chime in with helpful hints! We have a 2013 Georgetown 335 (bought it used with very little miles on it). Since we have had it, whenever I hook up to city water, it doesn't take long until water is running out of the overflow drain. I've read many posts about the siphoning effect and thought maybe that was my problem. But then...
I turned the city water off on the last trip and just pumped from my fresh water tank, since it was full. The pump ran intermittently not only on demand, but about every 2-4 mins when not demanding. Then all of a sudden, the pump got very loud. When I opened the access panel, several screws had backed out of the upper assembly and were laying on the floor. I figured I had found the problem, so I tightened all of the screws, except one that had sheered off. ( I even used a clamp on that corner to see what effect it would have). No matter how tight, when I turn the pump on, the vibration backs the screws out and eventually the upper assembly separates.
From previous posts I read, I am guessing the pump is the source of all my water problems. The check valve that is supposed to keep the city water out of the fresh water tank, the sheered off screw, the separating of the assemblies. My question is this: Is there another solution besides buying another pump? I've read there are some rebuild kits, but for $60 on Amazon, I'm thinking I'll bite the bullet and buy a new one. Any thoughts or comments on what I may be over looking would truly be appreciated!
