01-01-2018, 01:31 PM
#21
I have a 2015 GT. First, the clear plastic "little ball type thing" is simply the cover on a screen filter to prevent sand and grit from entering the water pump. (To my knowledge, there is no on/off switch on the pump.) Have someone inside the camper turn the pump switch on and off once or twice to see if you can hear the motor trying to run. Keep in mind that it automatically shuts off via a pressure sensor if it doesn't sense a need for water flow. So, be sure a faucet is open somewhere. If the motor runs briefly, then it is likely that you have one of the flow valves in the wrong direction. The position of the handles generally indicate the direction of the flow - if the handle is perpendicular to the line, it is off. If it is parallel with the line, it is open. Let us know what you find.
2018 Berkshire 38A
01-01-2018, 01:32 PM
#22
I could be wrong, the white hose with the blue stripe should be your water line for your unit from the fresh tank. Solid blue hose may be for winterizing. Turn the valve handle toward the striped hose and try that. Hope this helps.
01-01-2018, 01:59 PM
#23
Just a suggestion, did you get manuals on the rig when you bought it? I have a 36B5 which is a version of the one you have so, I think some of the piping is different on mine, but my dealer re piped mine to make it easier to figure out, there should be as I see on your pictures, that you have the white plastic valves at your pump. These valves, when open will have the lever parallel to the hose. 90 degrees off is closed. So, you need the one between the pump and tank opened, the one to the antifreeze hoses closed. Mine has the touch screen in the kitchen where I turn pumps on and off. They have to be turned on from where ever they are controlled. My other previous RV's had switches located in the same area as the monitor panels where you check for water levels etc for waste and fresh water. maybe you have that on yours. One of my camopers has a panel where my slide controls are and the pump on/off switch is there.
Dalin...(Dan & Linda)
2018- Georgetown- 36B5 GT
Veteran USN / RD3 68-74
Retired Electrician, Miller Brewery, 31 yrs.
01-01-2018, 02:10 PM
#24
I found some photos which might give an idea that are on these forums. here's the link to the feed where they are... http://www.forestriverforums.com/for...ve-103752.html ... hope this helps somehow.
01-01-2018, 02:42 PM
#25
Please do not confuse the bypass valves for the hot water heaters from the valve or valves that direct water from the fresh water tank or from an external source like a jug of antifreeze. That white valve in your picture next to the water pump is where you should look. If one valve, it changes the source to your water lines from the tank to an external source. If two valves are involved, one needs to be closed when the other is open.
"Lurch" = Georgetown 2011 330TS
Toad = Jeep 2016 Cherokee
Pilot = Bob
First Mate = Xiangbing
Crew = Radar, NiuNiu & NaNa
01-01-2018, 03:54 PM
#26
Another slim possibility since you see antifreeze in the little plastic bulb thingies is that one is cracked or loose making it impossible for the pump to suck. I had one crack and the pump ran but didn't pump water. The clear plastic part is easy to unscrew so you may want to xheck it.
DrLewie
Flemington, NJ
Former: 2007 Cardinal 30W LE
Now:2018 Arctic Fox 27-5L
2008 Ford F-250 Long Bed Diesel
Total of 30 Months on the Road Since 2008
01-01-2018, 03:59 PM
#27
When winterizing, anti freeze is pumped through the sediment filter, so you should see it in the clear bowl!
01-01-2018, 04:00 PM
#28
Drawn through not pumped through! My bad!
01-01-2018, 06:32 PM
#29
Thanks to everyone in this forum. You just saved me $200 !!
Neighbor in Davie Florida KOA just said he had to pay $80 for mechanic to come out plus 120 to look at his RV.
The white knobs were the ones I needed to turn! Pumps working great! Thanks so much ! You all are so much help to everyone. I can’t thank you all enough! Hopefully someday I will have knowlwdge enough to Pay It Forward to another person in need. Newbie or not. Have A Happy New Year!! DK
01-01-2018, 06:35 PM
#30
We appreciate your reporting back with your resolution.
01-01-2018, 06:44 PM
#31
Happy New Year and all is working as it should. Thanks for letting us know!
01-01-2018, 08:46 PM
#32
Thanks I watch this forum all the time and have learned so much in a short period of time from so many people with problems and many more with solutions! Thanks Again!
01-02-2018, 08:15 AM
#33
Dennis King, We have had our 364TS since Feb 2015. Have done many small mods and a major rebuild of master bed area. Trying to help others is a good way to learn as well. I should have said valves instead is switches in my prior post can see where that could have caused confusion. Anyway always I always keep an eye out for 364TS posts. Enjoy your trip!
2015 Georgetown 364TS, '05 TJ flat, or '14 Fiesta 5 spd w/Tandem Tow Dolly HDXL 8x10, & EZGO Customized Cart
Days Out '17-25{Days in Shop 141}; '16-59; '15-56.
2011 Flagstaff V-Lite 30WFKS '14-24, '13-33, '12-36, '11-29, '10-23.
01-02-2018, 08:18 AM
#34
Thanks so much! We love our 364TS got in July last year it sat on lot in Texas for a year I believe. Roof looks like they caulked it it more than once
01-02-2018, 08:32 AM
#35
We all were newbies at one time. We all had to learn, usually the hard way, as there was no internet and no forums. It won't be long before you are offering advice from what you have learned.
01-02-2018, 09:11 AM
#36
Thanks again!!
