Originally Posted by Ashlyn
Hey Dodge Guy
My LP/CO detector reached its 5 year lifespan now The solenoid shut the gas off on the rig. The new LP/CO detectors aren’t cheap. Do you have a schematic on how to wire up the solenoid so I can open/shut off electrically with a flip of a switch?
There should be 2 wires at the solenoid. 1 wire going to the detector for 12Vdc and 1 wire to ground. You're going to have to install the (SPST) switch in series with the 12Vdc wire and pick up 12Vdc from someplace because the default (deenergized) condition of the solenoid is closed.
Added: Sometimes the solenoid wires are different colors (yellow/black ground) but sometimes they are both black and would not matter which one is powered so you will have to verify which one it is for your switch install.
