My 2011 GT 373DS has 28" blades. The pivot arm (the part connected to the motor) connection to the blade holder is a non-standard width. The connection between the pivot arm and the blade holder is wider than most wiper blade holders available at auto parts stores (and Walmart) and do not fit. I gave up looking for new blade holders assemblies, and found the rubber (or silicone) blade inserts on line at ebay. After so much effort, I bought 10 for about $25. They came out of China in about two weeks. ...Easy to install with a ladder; I don't even remove the blades, just the silicone insert. The specification is: Black Silicone Windshield Wiper Blade Refills Inserts Width 8mm Length 28". 28” is 700 mm. I hope this helps.
-Richard
