04-23-2015, 09:03 AM
FLORIDA F.R.O.G.
1/2 Time Microwave Oven Replacement
Well, my 1/2 Time Micro finally died. I guess I am one of the lucky ones since my Lexie is an '06. I found an Emerson model MWG9115SB at Walmart for $89! It almost fits like a glove. The micro fits perfect, the existing outer grillwork for the 1/2 Time Over needed only minor modification due to the Emerson being about a 1/4" taller. It is VERY quiet, has 1100 watts, and a upper broiling element to allow you to broil and micro at the same time!
04-23-2015, 08:13 PM
Thanks for posting this info. I'll save it in case ours dies.
RamblerGuy
2011 Sunseeker 3100
2016 Ford Edge Toad
04-24-2015, 06:40 PM
FLORIDA F.R.O.G.
Replacement Con't
Well, I am back home from my week at Ft Wilderness at Disney World. I have completed the microwave install. Wow, looks like it came from the factory! I had to remove the first 2 upper horizontal bars of the old micro surround because the Emerson is taller. I also removed the feet on the Emerson, placed non-skid rubber on the old mount in the bottom of the micro cabinet, then adjusted the micro so I could use the existing holes to remount the surround. To see the pics you need to visit my Lexie Mods page; You may want to check out my couch replacement also. I installed one of the Theater Seating Loveseats from Camping World. All I can say is WOW!!! I feel like my little Lexie is a Prevost!!!!!!!!!!!!!
Micro Mod Link:
1/2 Time Oven Replacement - My Photo Gallery
06-02-2015, 02:58 PM
Micro Confused.
What about the gas cooktop? Is that still there and you just removed the innards of the microwave section (I see the control panel/clock part is still there in your pictures), and put in a different nuke? Curious because ours died and really cannot justify replacement with the same type due to cost. Was venting an issue? Thanks for the info.
Patti Z.
2011 Lexington 283
Springer Spaniel - Sheldon
06-02-2015, 05:59 PM
FLORIDA F.R.O.G.
1/2 time oven/cooktop
No problem. They are two separate units. The vented frame around the micro comes off with 6 screws and there it is. It will all make perfect sense when you remove that frame...
Rick Smith
06-02-2015, 11:01 PM
RV Nomad
Where did you purchase the Emerson. My 1/2 still works but I much prefer a full time microwave.
PLEASE IGNORE MY QUESTION. I see in your photo that you got it at Walmart.
06-03-2015, 09:56 AM
FLORIDA F.R.O.G.
Micro Purchase
Please not the first post above, Walmart.
RS
06-04-2015, 07:31 PM
We got our replacement at sears, actually quite easy to redo. Traded the Lexington so no pictures.
Bruce & Nancy Richardson
Lexington GTS 300 S/S
Chevy Avalanche
Jeep Wrangler
Honda Goldwing
06-08-2015, 12:50 PM
We settled on a Panasonic model #NN-SN651B. The Emerson mentioned above as out of stock at our Wally World. We added a 1" board below it to raise it up some. An additional .5" would have been perfect, but used what we had on hand. That left a .5" gap at the top (using the old trim plate), but not really noticeable. The door of the microwave fits the old trim opening perfectly. There is about a .5" gap on each side, but also not really noticeable. Whle at it, we replaced the 26" TV with a 32". That was a large as the spot would allow.[URL="http://www.forestriverforums.com/forums/members/49748-albums2305.html"]
Patti Z.
2011 Lexington 283
06-09-2015, 08:45 AM
Patti Z.
2011 Lexington 283
06-15-2015, 09:11 PM
Completed the microwave mod for our 2008 Lexi 283gts, as RickLSmith53. Same mod to the old trim ring. Only difference is I installed a convection micro. Not counting the time to buy the replacement appliance it was a 5 hour job with the occasional extra set of hands - thanks to the DW.
2016 Sunseeker 3010ds towing a 2013 Ford Explorer 3.5L AWD.
